All Things Mk5 => How to Guides / Troubleshooting => Topic started by: SyntaxTerror on July 11, 2012, 07:38:05 pm
Title: 2008 Golf GTI Ed30 - Sluggish in low revs, very (very!) low MPG
Post by: SyntaxTerror on July 11, 2012, 07:38:05 pm
Hey All,
So my Ed30 hasn't quite been the same since its recent Major service (a few months back).
Currently, i am averaging 22mpg on my journey to/from work, which is 25 miles, but mostly urban. This is a definite contrast to the 27/29 i have been used to!
Also, from low revs the car feels weak, and rev-up is a little jittery (but only just noticeably so). Power also feels reduced in mid to high revs, and the activation of the turbo at the 2500rpm mark feels a lot more pronounced than it ever has before.
Checking for engine fault codes with VAG-COM shows no issues!!
I am expecting this to be a PCV failure, possibly also a MAF failure. However, doing the recommended PCV check of removing the dipstick while the engine is running causes the idle to become rougher slightly, then return to its normal idle (along with a whooshing sound of the air escaping) which implies to me that this isn't the problem!?
I'm about to book it in with the stealers who performed the major service, just wondering if anyone had any thoughts on the above, or could let me know something else i can test using VAG-COM that might let me know what the issues are before i take it in.
ta :)
edit: also, completely standard setup, no mods!
Title: Re: 2008 Golf GTI Ed30 - Sluggish in low revs, very (very!) low MPG
Post by: flyboy1976 on July 11, 2012, 08:24:08 pm
Diverter valve perhaps...easily checked
Post by: SyntaxTerror on July 11, 2012, 08:34:09 pm
Thanks mate, had the DV fail a couple of months before the major service, and it was replaced with the latest rev.
As far as i can tell, it's still in action. Still clearly hearing the familiar PSSHHT on dump, and turbo spooling noise. Will check it though!
Post by: flyboy1976 on July 12, 2012, 08:41:40 am
Have you looked at the plugs and what is the mileage of the car? when were they last changed? You said it has had a service recently....has the problem surfaced since that event...if so what work was carried out? also has it got the latest revision of coil packs installed as they were a recall from VW FOC so if you are unsure then go to you nearest dealer and ask if it has been done (if not get them to do it)
The latest revision of coil packs are 'F's' iirc and the (replaced) diverter valve should be either a 06H revision 'C' or 'D' or even a 06F revision 'G' (if you look on the side of the diveter valve you will see the full part number, note it down and get back to me)
PCV could be an issue and aren't too much money to change, the last revision i last heard of was an 'N' but ask someone on here who has access to ETKA to confirm.
Post by: flyboy1976 on July 12, 2012, 08:47:13 am
http://www.golfmkv.com/forums/showthread.php?t=24952
Post by: SyntaxTerror on July 12, 2012, 09:38:09 pm
Thanks Flyboy!
Mileage is 36k. Not looked at the plugs, but they weren't changed during the major service. Did fit a new Cam-Belt and Water pump. As for the coil packs, i think the 2008 model was later than the RMA if my memory serves me correctly (anyone know this)?
After the service i did notice some oddities with the car, the revs didn't feel quite as smooth as before, but overall the car felt ok. The issues i've been having have slowly increased since the service, it hasn't ever felt 'perfect' since having the work done.
Thanks for the heads up on revisions. Currently its absolutely crapping it down outside so i can't really go and check :/ wish i had a garage :( However, I've fished out the parts list from the DV change, and it's the revision G: 06F145710G
I'm going to request that the PCV is changed, even if they don't find fault with it, as the latest rev rumoured to be significantly tougher.
I'm booking it in for next week, so any pearls of wisdom are still much appreciated!
Thanks again
Post by: flyboy1976 on July 12, 2012, 10:25:10 pm
Get VW to check and see if the have bashed the N75 valve on the turbo when doing the cambelt.
I would get the plugs swapped out ASAP fella (unless the car is mapped just go with the OEM ones) as i bet they are the originals in the car and at 36K they have seen better days. what fuel do you run the car on....i use tesco momentum 99 or shell optimax....always put decent fuel in buddy. Another thing is to change the fuel filter, now here is the thing....fuel filter change is not part of ANY part of a VW service schedule at all on this vehicle. Check the diverter valve anyhow for splits...its just three trx bolts and an electrical plug. Any further help just shout me!
Post by: DSG-GTI on July 14, 2012, 07:46:11 am
Did you have the cam belt changed... if so It sounds like they have got the cam timing wrong !!! it seems to happen quite a lot...
Post by: SyntaxTerror on July 14, 2012, 06:05:37 pm
Thanks gents,
I always fill her up with v-power :smiley:, (used to make) a noticeable difference to mpg.
Also found the Major service doc and the plugs HAVE been changed! (so, possibly bad ones)
When i spoke to Allan Day (the original servicers) they've told me:
"We can't do anything unless its throwing a fault code"
Great service, thanks guys! :stupid:
So, yesterday i contacted TuningWerkes and got a response from Reuben saying he will take a look, i've heard good things about them. i've been wanting the APR flash for quite some time, just wanted the car to be perfect again first!
I'll point him to this thread, he might want to leave some feedback.
Thanks again for all the suggestions
Post by: DSG-GTI on July 14, 2012, 07:11:35 pm
If it was dropping a plug it would show up in the diagnostics wouldn't it ... I run mine on all different fuel and it never misfires ... just goes better on the V power  :wink: I would still like to bet the cam timing is a couple of teeth out... I would take it to a good tuning place and get them to check it ... wouldn't be the first time a dealer has got it wrong !!! might be wrong but it may save you a lot of time and money not to mention the stress in the long run. Good luck bud and let us know how you get on  :happy2:
Post by: alackofspeed on July 16, 2012, 10:14:05 pm
Another vote for the timing belt. Crops up far more often than it shoud on here - seems a surprising number of garages can't get the very simple job done properly! Good job there are only two toothed wheels to line up on a TFSI.... imagine the errors a garage could make with 5!
Post by: DSG-GTI on July 17, 2012, 08:08:03 am
I wouldn't take my single cylinder OHC lawnmower to my local dealer.... Trouble is my belt is due in October and as I have warranty with VW Im going to have to take it to the dealer I bought it off (not my local one) but Shrewsbury VW .... so far these guys seem ok ... I had the air con compressor fail and they sorted it with no hassle so fingers crossed they get it right.... plus maybe a word in the "fitters" ear telling him I built CAT engines for years... so get the effing belt right... that should do the trick  :smiley:   plus I will be driving it up the road before I pay the bill... oooops rant over now... it just annoys me that people pay good money then get a load of hassle getting a problem put right that wasn't there in the first place. Anyway like I said to the OP let us know how you get on.
Sorry for the rant and hi-jack  :smiley:  :smiley:
Post by: 56OctyVRS on July 17, 2012, 04:22:22 pm
As long as you take it to a garage that uses Genuine VAG parts your warranty is still valid. You dont have to use main stealers anymore to keep your warranty.
My bet is that they are a tooth out on the belt and the timing is wrong or the tensioner is not correctly set up and has let the belt jump.  Makes you wonder if they actually manually spin the engine round to check once the belt is fitted and double check then triple check its all okay.
Post by: DSG-GTI on July 18, 2012, 07:17:58 am
Really ... must look into that  :happy2:
My previous car was a Mk4 GTI diesel 150 had it 8 years and used a local fella to do services and the cam belt .... come to think of it that's all it ever had done... other than brakes/discs/air con gas... great motor... fella has been in the trade for years and knows his stuff so I would much rather him do it, Must give him a bell thanks for the info.
I would bet it's the inlet cam that's out .... tensioner side  :wink:
Post by: Frodo-anni on July 18, 2012, 09:20:03 pm
Would a cambelt timing being out cause any damage other than just poor performance?
Post by: Statller-Stevo on July 19, 2012, 10:53:07 pm
As long as the fool who's done the job gets it no more than a few teeth out it won't hurt,  just causes the exact symptoms described
A 2.0 Tfsi belt is a doddle to fit, I really can't believe how many are fitted wrong :confused:
Post by: JpowerGTi on July 20, 2012, 01:04:03 pm
All the advice is brilliant lads I really appreciate it!
Post by: SyntaxTerror on July 21, 2012, 06:22:05 pm
UPDATE :smiley:
You lot are awesome. Thanks again for the great info.
So, this week the car went into TuningWerkes, and Reuben and his team worked through the problems i described above. The service these guys provide is top notch, the level of knowledge Reuben and his team have is seriously impressive!
Results: She is now back to her normal self! MPG is back on par and we even dropped in the APR re-flash (although drove it on standard mapping for a good while to test it out)
What changed:
1. Plugs had seen better days, swapped out with NGK Iridium
2. PCV replaced
3. And as you all thought, Cam belt was 1 knotch out!!
Before:
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi.imgur.com%2Fq7UvQ.jpg&hash=57bd57a6050800917d273a9c100cf92c478d736e)
After:
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi.imgur.com%2FjV9op.jpg&hash=1fff24f847c80cfdd293ce4fbd678247bfe41c6b)
So, i'm going to have a bit of a moan at the original dealer to see if they can re-fund some of the initial cost... i'll let you know how that goes!
Thanks guys, and huge credit to TuningWerkes who i'll definitely be going back to in future.
Post by: bacillus on July 21, 2012, 06:57:28 pm
Great result...   :happy2:
Post by: mad_pete on July 21, 2012, 10:31:14 pm
Nice.  So scary that this can get messed up.  Surely check and re-check on little white marks lining up is easy enough.
Post by: werkes on July 24, 2012, 10:21:16 am
UPDATE :smiley:
What changed:
2. PCV replaced
Before:
After:
Hi mate,
Thanks for the review of our work and positive comments!
It's good to know your car is back to where it should be and you have the bonus option of the APR software now too!
Look forward to seeing you again sometime!
Regards
Reuben
Post by: Saintsteve on July 24, 2012, 10:27:16 am
 :congrats: :congrats: to the guys for diagnosing this  :happy2:
Post by: DSG-GTI on July 29, 2012, 09:21:54 am
Good to hear you got it sorted bud... What is it with cam belts that people cant get right   :scared:
Post by: alackofspeed on July 30, 2012, 11:14:17 pm
Gotta wonder about the mechanics "fitting" these cambelts, as anyone who has ever fitted one will know that fitting the belt is really very easy :stupid:. The annoying part is gaining access.
Post by: Scrubadub on August 05, 2012, 06:17:20 pm
If its only 1 tooth out it shouldnt cause any major damage, but im also betting this is whats wrong
Post by: GS WAX on September 02, 2012, 08:10:00 am
 Glad you have it sorted, This topic inspired me as I had the same symptoms with my ED30.Changed PCV,DV and plugs,slight improvement but not quite "how it was" ,then changed DV to the G revision from the MK6 D rev and what a difference,all is purdy again.
