All Things Mk5 => Mk5 General Area => Topic started by: zenicman9 on August 10, 2012, 04:44:51 pm
Title: Hybrid Help
Post by: zenicman9 on August 10, 2012, 04:44:51 pm
Hey
I am looking at getting this - http://www.turbodynamics.co.uk/shop/md505-stage-2-hybrid-turbo-for-vag-19-tdi-105bhp-engines-p-2758.html
Would I need to replace my fly wheel clutch etc?
Title: Re: Hybrid Help
Post by: DFish on August 10, 2012, 05:08:38 pm
Depends on the milage on the current unit, you might be able to get away with it.
Fish
Post by: zenicman9 on August 17, 2012, 01:53:54 pm
Thanks, They have said Ill need a new inter cooler. Is there any you would suggest?
Post by: JoeDarKa on August 17, 2012, 02:31:26 pm
Have a look at darkside developments. Its probably going to be an S3 one
Post by: Andy on August 17, 2012, 04:25:05 pm
YOu only need a new inter cooler as you will loose a few bhp in the summer,but when does it get hot here :signLOL:,leave the inter cooler for now and get the clutch like I am
Post by: zenicman9 on August 17, 2012, 04:35:49 pm
So i could get a hybrid and just do the clutch?
Post by: Andy on August 17, 2012, 04:41:20 pm
That's what am going to do and see how it goes,in the hot weather you get a bit of heat soak and loose a bit of bhp you can get the s3 cooler put on
Post by: zenicman9 on August 17, 2012, 04:44:11 pm
The guy reckons id be running close to 200bhp with the hybrid
Post by: Andy on August 17, 2012, 04:52:14 pm
IS yours a must be a 1.9tdI :happy2:
Post by: zenicman9 on August 17, 2012, 04:54:00 pm
Yeah mines a 1.9 do you reckon thats about right?
Post by: Andy on August 17, 2012, 04:57:03 pm
Should be any where above 180bhp but with the right map its possible
Post by: PDT on August 17, 2012, 05:21:53 pm
Hi,
I have mapped a few 1.9 tdi 105 with hybrids, you will need a decat, intercooler and stronger clutch as a must. 320 ftlb and 185hp is possible with time spent mapping it correctly on the dyno. Our stg2 makes 275 ftlb and 155hp without the hybrid on a stock engine and with cooler and decat 165 and 280 is achievable. I would also advise new seals and clips for all of the boost pipes before mapping it, and give them all a good clean, we spend longer fixing boost leaks than actually mapping on most hybrid TDI setups.
Title: Re: Re: Re: Hybrid Help
Post by: Trekmeister on September 02, 2012, 10:47:40 pm
Hi,
Would a decat and intercooler also be a must on the pd140, if so what would happen without?
Post by: Andy on September 02, 2012, 11:00:10 pm
DEcat and exhaust for def
Post by: DFish on September 03, 2012, 01:15:40 pm
Decats help without question, the I/C should be fine though.
Fish
