All Things Mk5 => Mk5 General Area => Topic started by: benheaven on August 20, 2012, 08:01:07 am
Title: Brake Calipers and Hub Painting
Post by: benheaven on August 20, 2012, 08:01:07 am
Hi Guys,
Does anybody know of a Brake Caliper and Hub painting service in the Surrey area?
Looking to get the car all tidied up this Month.
Ben
Title: Re: Brake Calipers and Hub Painting
Post by: Padraig on August 20, 2012, 10:31:58 pm
I done all 4 of mine over the weekend,
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fq634%2Fpadraig5%2F29.jpg&hash=e0b2bc4f68010440c82c453c388875e9968595a9)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fq634%2Fpadraig5%2F30.jpg&hash=51a52e9ff90fb683b98deeac5b66171c505e6137)
Post by: micaerin on August 20, 2012, 11:06:01 pm
They look great. What paint did you use? and how much prep work was involved.
Post by: Padraig on August 21, 2012, 12:33:31 am
Prep work is the hardest and most important part of it,
Used medium-fine wet sandpaper to give everything a really good sanding, also used brake Caliper Cleaner,
Gave Calipers and Hub's a thorough cleaning and wiped dry,
To spray the hubs i masked off everything, including the calipers,
Gave them all 2 coats of Grey Hallfords primer,
Left over night to dry,
Then gave them all 3 coats of Hallfords Black Matte, light sanding in-between coats,
For the calipers i used Hallfords Brake Caliper Paint,
Used 2 brushes, really small one for the hard to reach places,
Gave them 2 coats, 1hr in-between,
Next day before fitting the wheels back on,
I gave the 4 hubs and calipers 1 coat go Gtechniq C5 Alloy Wheel Armour, (just thought it might make it a-bit easier to clean and keep clean)
Don't know how long they will stay like this, but for now i think they look a lot better and easier to clean,
I also sanded, cleaned, primed, and sprayed all the wheel bolts matte black,(3coats) just to take that rusted old look off them.
Hope this helps,
Cheers,
Post by: robern2 on August 21, 2012, 08:16:31 pm
Don't know about Surrey but more than just wheels did a fantastic job on mine...in Nottingham.
Hi Guys,
Ben
