All Things Mk5 => Mk5 General Area => Topic started by: gigolo456 on December 04, 2012, 05:04:18 pm
Hi Folks, yes i have used the Search function but for the life of me, i can't find anything that details what's involved in changing the front and rear number plates!? Anyone have any links by any chance? :driver:
Many thanks
Andrew
Is that just so you can fill up the tank for free :grin:
Sh*t, my secrets out! ;-)
Many thanks
Andrew
You just unscrew them :confused:
Many thanks
Andrew
I think more detail is needed. Are we talking about stuck on plates? Because 90% of cars are just two screws under covers which just pop up
Thank u 4 the constructive comments folks! Mine r stock and screwed in so to speak! Am being given a personal plate 4 my impending 40th, lol, so assuming they r just plates, so is it best to just stick new ones on, after removing current ones of course, r have them drilled and screwed in, ie proper dealer job??
Cheers!
What !
Can you not use a screwdriver :rolleye:
I give up, lol, I assume new plates dont come with ready made holes in em, plse correct me if im wrong!?
Use the old plates as a template drill throught the old ones and through your new ones , go from the front to the back (The white or coloured bit drilled first ) Use a drill bit for wood and use an electric drill , put the drill bit in the electric drill and press the button putting the drill bit where you want to drill the hole and press firmly .
PS . Make sure the plates are not on your lap.
Oh we have a comedian I see! Trust me, the only DIY I do is after the watershed, lol! Halfords fit them anyway for £6 apparently, jobs a good'n, I hope! ;-)
this is literally one of the easiest mods you will ever be able to do. dont take it to halfrauds - like GarrardRJ says and just put the old ones on top of the new ones (a little masking tape holding them together helps so they dont move), and drill through.
Seriously i cannot believe there is so many posts on this :evilgrin:
Or just buy some self adeshive tabs, stick to back of plate and stick to car, hold firmly for 20-30secs, Job Done :happy2:
No drill, yes u heard right, lol, and im sure my 7 yr old screws will need changing, and sum of the caps are missing too, and they come as part of the Halfords job! Thanks thou for the suggestions!
Halfords should be ashamed to change peeps for something my 8 month old granddaughter could do while fast asleep and holding onto her Ninky Nonk (don't ask :laugh:) all at the same time.
hopeless at diy, and a bad stutter, poor man
I do actually have a stammer, lol, but u shud c my gal! :-P
:worthless:
Buy her a drill for Christmas and she can fit the number plate for you! :grin:
The only thing you need to have to do with halfrauds is to go in and purchase their number plate sticky pads... dont give them buggers the money for a simple job!!
With the old plates off, just make sure you clean the surface properly so they can get decent adhesion.. also, allow them to fully cure for 24hours if you can before you take the car anywhere, just so to prevent dibble chapping your window when your out and about, saying that they're pretty strong so even a couple of hours should be ok..
Theres two different thickness, 1mm pad and 6mm pads.
I've got the 1mm's on both front and rear, just make sure you line them up correctly before you press them home.. also make sure its not like -40 outside!
When it comes to removing the plates, just get some dental floss and run it behind the plate and it should lift off the car no problems. if you then want to clean the remnants of the pads off the plate/car, i've used AutoGlym intensive tar remover and its worked a treat!
Dont go to Halfrauds their plates are ridiculously priced and the spotty teenager will not put it on straight. Buy plates on line and use sticky pads it'll look a cleaner job.
If you drill use some tape too as it can help stop the plate cracking.
