All Things Mk5 => Mk5 General Area => Topic started by: saadn on December 09, 2012, 05:08:38 pm
Title: Installing Xenon Headlights
Post by: saadn on December 09, 2012, 05:08:38 pm
I've got a complete set of xenon headlights with the 10-12 pin adapters for my gt tdi. Is installing simply a case of removing the halogen lamps and connecting the xenons using the adapters or does it require more extensive work? These are the adapters I have:
http://www.ebay.co.uk/itm/390409641277?ssPageName=STRK:MEWNX:IT&_trksid=p3984.m1497.l2649
Title: Re: Installing Xenon Headlights
Post by: apples12 on December 09, 2012, 05:31:08 pm
Will most likely also need coding with vagcom, I'd highly recommend installing the pin 11 wire for the high beam shutter
(I like the sig :happy2:)
Ali
Post by: saadn on December 09, 2012, 07:22:08 pm
Ali
How would I go abouts installing pin 11?
Might need to put that as a decal on the car.
Post by: thegolfather on December 13, 2012, 01:25:46 am
i'm interested too, any updates on 11 pin and why?
Title: Re: Re: Installing Xenon Headlights
Post by: jason_rmh on December 13, 2012, 07:09:00 am
Pin 11 activates the bi-xenon functionality which opens a shutter when on high beam.
Jas
Post by: saadn on December 13, 2012, 08:14:05 am
http://www.myturbodiesel.com/1000q/a5/HID-retrofit-Jetta-a5.htm
I followed this tutorial. Still need to install pin 11 and get them coded.
Post by: Moz on December 13, 2012, 03:47:21 pm
Same here, I  had help installing Xenons. but it's as easy as lights out lights in. once you remove under tray and front bumper.
You'll need a wire for Pin 11 runs through the bulk head to the CCM under the pass side I believe and then re activating as Bi Xenon in VCDS,
Post by: saadn on December 14, 2012, 08:54:06 am
Isn't it wired to under the drivers side?
Post by: GTI_UK on December 14, 2012, 11:50:12 am
Does anyone have a pic of what the shutter looks like? (might be a silly question).
I bought some Brand new OEM replacements and they have (exactly like the OEMs) a halogen for high beam - so how does this shutter work? Both the halogen high beam and xenon come on together?
Post by: thegolfather on December 14, 2012, 05:34:11 pm
thanks for info
Post by: Moz on December 14, 2012, 07:28:27 pm
Possibly I can't remember, but it goes to the control unit , I'm not sure which side this is on.
Post by: saadn on December 15, 2012, 11:19:00 am
 This video may help you out a bit.
