All Things Mk5 => Mk5 General Area => Topic started by: northyracing on February 26, 2013, 05:32:07 pm
Title: Pcv valve
Post by: northyracing on February 26, 2013, 05:32:07 pm
Been havin idle problems and juddery feeling so checked my pcv today I done the blow down the pipe test. I took it off inlet manifold side and blew down the pipe and took oil cap off and you could hear that I was blowing straight through the pcv into the engine also noticed the pipe had quite abit of engine oil in it would this suggest the pcv is naffed
Title: Re: Pcv valve
Post by: MC71 on February 26, 2013, 05:36:49 pm
With the engine on, pull the Dipstick out, if the engine starts to run rough then all is well but if it continues to run smoothly then it needs replacing.
Post by: northyracing on February 26, 2013, 05:57:31 pm
It runs rough wen dip stick is out but can blow straight through pcv
