All Things Mk5 => How to Guides / Troubleshooting => Topic started by: adgti on April 09, 2013, 07:20:16 pm
Title: Help p0299
Post by: adgti on April 09, 2013, 07:20:16 pm
So today I decided to change my diverter valve to the latest revision G. Fitted it took the car up the road & I got a sound like a high pitched sqeel like a boost leak? Anyway drove another mile then I got a massive missifre with a cel turns out the coilpack has gone luckily I am having them recalled on friday. Any ideas on a boost leak?
Title: Re: Help p0299
Post by: adgti on April 09, 2013, 09:33:32 pm
bump? any common boost leak places?
Post by: adgti on April 10, 2013, 07:42:22 pm
bump still cant find this leak
Post by: rich83 on April 10, 2013, 07:44:09 pm
Have you tried re-fitting the DV? Might have not been set in correctly
Post by: adgti on April 10, 2013, 08:44:11 pm
To be honest no but it looks ok. I will remove & refit tomorrow though
Post by: PDT on April 10, 2013, 09:06:02 pm
Check the joint from the inlet to turbo, this often causes squeel noises when not sealing.
Also make sure the DV is on correctly, it has a small locator bump on it that must be fitted in the correct location on the turbo housing.
Post by: adgti on April 11, 2013, 12:39:44 am
hmmm could be that as I have also just fitted a CAI. I have removed the dv again & put it back on the same way I took the old one off. Although when I took the new one back out it fell apart  :confused:
Post by: adgti on April 11, 2013, 11:52:54 pm
Checked intake to turbo pipe it's all tight. Really can't find the leak I think it's from the pass side
Post by: xjay1337 on April 12, 2013, 12:06:12 am
Make a boost leak tester, I think you can do this with coloured air/smoke into the intake?
