All Things Mk5 => How to Guides / Troubleshooting => Topic started by: bRinkz on April 15, 2013, 09:05:52 pm
So yesterday I fitted my 24mm RARB to the Cupra. Tightened up the D bushes with the clamp nice and tight, tightened up the drop links. Now, I did the drop links whilst her backside was still up in the air - I just used the jack to push the hub upwards and line things up, but obviously had to do one side at a time.
I took her out staright away and all felt fine, no noises and nothing fell apart - job was a good one. So i'm coming home and I go over a speed bump outside a school, you know, one of those raised zebra crossing things. Hear a slight 'clunk' as the back went up and off it. I didn't worry too much.
So gets up this morning and takes the little one to school - village school, up some country roads. I'm hearing constant clunking from the back end. I goes to work and parked up in the local multi storey, as i'm navigating my way up i'm hearing the clunks every time i hit a ramp. So I called APS where I got the bar from and chatted with Ed, he reckons I put the D bush brackets on to tight and the bar isn't rotating as it should, thus putting pressure on the drop links and causing the noise.
I gets home tonight, jacked her back up and loosened the brackets and tightened them back up to a max 30nm.
Still getting the same flipping noise when driving casually :sad1:
Now if I put her under load in a corner I hear nothing, drive steady in a straight line or around a bend and 'clunk, clunk-flipping-clunk'.
Have I simply cream crackered the drop links???
You shouldnt have had to push the suspension arm up to fit it... you should be able to fit it with the wheels hanging loose.
To be fair I didn't have to push them up too far, just to help manipulate the droplink back in place.
I forgot to say that I put it on the tightest setting of the two.
