All Things Mk5 => Mk5 General Area => Topic started by: MrDo on April 24, 2013, 09:50:07 pm
Title: Mirror controller moves both mirrors at same time?!
Post by: MrDo on April 24, 2013, 09:50:07 pm
I just swapped out my old window joystick/switch controller on my UK MK5 GTI for a chrome knobbed brand new one (as used on Passat, MK 6 etc) bought on eBay. When I set it to move the left mirror it works fine, but when I move it to adjust the right hand side mirror it moves both bloody mirrors ie both the right and the left mirrors at the same time!!
It is a joystick/switch for a RHD car. Surely this part does not need coding? Maybe a duff switch?  :sad1:
Title: Re: Mirror controller moves both mirrors at same time?!
Post by: stealthwolf on April 24, 2013, 09:57:32 pm
Normal behaviour and a "feature" of the golf.
Post by: GrayMK5GTI on April 24, 2013, 09:59:16 pm
I'm sure this "feature" can be disabled with VCDS  :wink:
Post by: neg on April 24, 2013, 10:11:22 pm
Your right - on the mk6 you can enable/disable via the MFD
Post by: MrDo on April 24, 2013, 10:18:42 pm
Why on earth would they choose to do this? Never noticed it in the past 6 month..... Funny how you miss things eh?
Anyone done this? Know the code etc?
Thanks  :happy2:
Post by: neg on April 24, 2013, 10:25:37 pm
it does make sense, you adjust the right first then the left, then if you need to adjust (or another driver does) then adjust the right only and the left is pretty much (I have found) in the right place - then when you come to move it back, its one mirror - move to your location, check the left and if your lucky its spot on.
Post by: ripmateyy on April 24, 2013, 10:27:53 pm
I think you can change this in convenience menu on highline
Post by: bacillus on April 24, 2013, 10:44:54 pm
Correct, if he's got a highline mfd.
Post by: MrDo on April 24, 2013, 11:18:05 pm
Sadly not, but I do have VCDS if I can turn off via that?
Post by: neg on April 24, 2013, 11:22:17 pm
Yes you can.
Post by: Kalpsn2000 on April 24, 2013, 11:34:39 pm
Ignore, wrong thread.
Mod can delete.
