All Things Mk5 => Mk5 General Area => Topic started by: WILLZIE on May 06, 2013, 08:41:43 pm
Can anyone please tell me where I can get genuine front pads and discs please other than the dealer!????, got quoted £240 for discs and over a £100 for just pads, been a few years since I bought pads but that seems a hell of a lot of money.
Thanks.
Check out my post here: http://www.mk5golfgti.co.uk/forum/index.php?topic=63918.0
Basically you can contact your local TPS and see if they will sell to the public, some do, some don't.
I bought loads of stuff from David who is in the second post of that thread, he is a top guy and all the stuff he sent me was spot on.
I got a quote from him recently for discs & pads for the GTi:
GTI Brake Disc (Front) 312 x 25mm --- 1K0 615 301 AA £79.66 a pair
Economy version - JZW615301H £66 a pair
GTI Brake Pads (Front) --- 3C0 698 151 C £40.61
Economy version - JZW698151B £30.66
GTI Brake Disc (Rear) 286mm x 12mm --- 1K0 615 601 AD £55.50 a pair
GTI Brake Pads (Rear) 1K0 698 451 G £29.60
Economy version - JZW698451D £20.60
Parcelforce is £12 per axle so £24 for all brakes.
The Economy versions are genuine VWG parts but in a promotional range for older cars.
Regards
Hope that helps :happy2:
Can also vouch for David@SERE if you want OEM mail order, bought loads through him.
Try a local TPS, or if you want OEM quality try a local garage in the Bosch network to supply them.
Your local Andrew Page will supply Bosch discs and pads, or GSF will also supply brembo.
Thank you peeps! :smiley:
Bought OEM discs and pads for £220 the other week via TPS.
I put some Brembo discs on. They lasted 3 weeks before warping. Not impressed.
