All Things Mk5 => Mk5 General Area => Topic started by: Aweful_Truth on May 20, 2013, 09:09:42 pm
Hi chaps, how can I get camber on the rear please? I'm not very knowledgable on these things!
Post 34
http://forums.vwvortex.com/showthread.php?4442430-How-to-adjust-rear-camber (http://forums.vwvortex.com/showthread.php?4442430-How-to-adjust-rear-camber)
Personally i got an alignment and told them what i wanted the camber set to.
If you do adjust it yourself make sure you get an alignment after as it will throw your toe out :happy2:
As above. I had 4 wheel alignment done the other day and had my camber reduced and the toe needed sorting too.
Hunter alignment is what you need. Google alignmycar :)
Thank you guys :)
