All Things Mk5 => Modifications & Technical Area => Performance Modifications => Topic started by: paulmk5gti on July 07, 2013, 05:22:24 pm
Title: Anyone recommend a good clutch upgrade
Post by: paulmk5gti on July 07, 2013, 05:22:24 pm
As above running mk5 gti with CDL Engine REVO stage 3. Take a look at the pics epic failure :) (https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi1283.photobucket.com%2Falbums%2Fa559%2Fpaulmk5gti%2F20130706_222016_zps0f69283a.jpg&hash=784fcd35dfe16304edee1b64a9a9e4db72d883c4) (https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fi1283.photobucket.com%2Falbums%2Fa559%2Fpaulmk5gti%2F20130706_222110_zps27197020.jpg&hash=2bf3994d2d561277a20ae1dd51340cf6f211504f)
Sent from my GT-I9300 using Tapatalk 2
Title: Re: Anyone recommend a good clutch upgrade
Post by: Neiltdi on July 07, 2013, 07:04:44 pm
That's alright it will go again :wink:
Title: Re: Re: Re: Anyone recommend a good clutch upgrade
Post by: paulmk5gti on July 07, 2013, 07:18:53 pm
lol :)
Post by: GrayMK5GTI on July 08, 2013, 07:39:26 pm
When I was after a new clutch I did loads of research. Sachs had a lot of bad reviews so I would have gone Helix. Awesome GTI are quite cheap, get it fitted at your local specialist   :happy2:
Stay away from techniclutch on eBay  :scared:
Post by: 5971danny on July 08, 2013, 09:03:14 pm
Y techniclutch off ebay ive just bought 1  :signLOL: :sad1:gulp ?
Post by: lee_plum on July 08, 2013, 09:37:33 pm
Loba is the safest option for putting alot of power through surely
Post by: danishmkvgti on July 09, 2013, 08:45:48 am
I will recommend a sachs uprated pressure plate and clutch with a DMF for your typical fast road use, with the LOBA SMF solution as the next step with track days thrown into the equation.
I can't recommend the Sachs SMF solution as it seems their SMF is designed wrong and can result in the clutch being sucked to the SMF which results in not being able to shift at high rpm and do fast shifts.
Both Fuscobal and i have had this issue with the Sachs SMF setup.
 :drinking:
Post by: GrayMK5GTI on July 09, 2013, 09:40:08 pm
Google them  :scared:
Post by: lee_plum on July 09, 2013, 10:32:47 pm
Yeah for every good review there is two bad ones
Post by: SyntaxTerror on July 10, 2013, 12:37:07 am
I'm running a Helix Fast Road clutch and SMF after a similar experience
Helix clutch works as it should, and doesn't seem dissimilar to standard, but clutch weight felt like gym equipment initially! Its gradually loosened up over the last few months to a more tolerable level.
One thing worth considering, the SMF does noticeable improve engine pick-up, but the idle noise is terrible, even after a few months of having it installed, often sounds like a tractor! I'm tempted to return to a dual-mass.
Post by: paulmk5gti on July 10, 2013, 10:46:12 am
I have been looking at helix clutches and wondering if it would be best to run smf or dmf is the chatter from the smf really that bad?:'(
Post by: SyntaxTerror on July 10, 2013, 02:42:52 pm
I guess it depends on your priorities! It can sound pretty loud and nasty at idle, to the point where people have commented on it. If your not bothered by this then by all means go SMF. I was expecting less noise from it tbh, and it seems to randomly fluctuate in volume at times.
Post by: vRS Carl on July 10, 2013, 03:24:33 pm
I had a Sachs clutch and Flywheel in my last Octavia vRS and never had any issues with it, well apart from the wife complaining it made her leg ache in traffic  :grin:
Post by: Twiggy on July 10, 2013, 03:34:48 pm
Statller fitted me a Helix clutch and dual mass flywheel as i didnt want the chatter, clutch will hold 354ftlb from what i have read online.
Was stiffer than the standard clutch but nothing ridiculous.
Love it  :smiley:
Post by: robern2 on July 10, 2013, 09:55:51 pm
Love it  :smiley:
i have the helix on my stage2+ ed30 with the original dmf.
Clutch is barely stiffer than standard
Post by: Pete R on July 11, 2013, 12:40:59 pm
Try cg motorsport
