All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: Shanny on August 17, 2013, 02:01:15 am
1) I Require A canbus gateway as I have a gt tdi golf mk5 54 plate.
I will be upgrading my stereo to an RCD 310.
2) I will also be eventually fitting a MFSW and highline clocks.
Currently I have the midline 961 clocks. I believe I require 971 clocks as no others will fit, is this correct?
I have seen some 972f clocks from an r32 that I want to fit.
They are off a DSG but mine is a manual.
Can Eddie get these to work with mine.
I'm based in Manchester.
Yeap. Get your post count up to 10 and PM him. :happy2:
972 clocks will be fine, perfect if your new MFSW has the newer button layout. In the meantime you won't be able to access the menu as you lack the MFSW menu button but could still scroll through trip functions. Gearbox makes no difference :happy2:
you can get a pre-coded one for the same price as the one on ebay
Thanks Eddie
Can you Pm with your details, I would like to purchase one.
Thanks Eddie
get your post count up
Hi Eddie
Just got my car scanned with vcds, I have the files waiting to email across to you so you can code the new Canbus for me.
Thanks.
P.s. do you know anyone who can get the code for the rcd-310 I have installed.
I have the vin number it came out of and the serial number of stereo.
Ed!
I'm looking at getting a CANBUS for my mk5 too; I had previously spoken to you on another forum; but it seems this is your favourite hideout.
I've finally bitten the bullet for a RCD310 and hence need to get a new CANBUS gateway to support this. Let me know if you can help!
Thanks,
Ian
Received my CANBUS from Eddie-NL last week.
Working perfectly fine no problems.
Thanks Eddie
Hi, I was forwarded this thread and told Eddie's the guy to go to for a CAN BUS gateway.
I'm not a MK5 owner, I've got a Passat B6, are you able to help?
@Eddie-NL (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=2345)
