All Things Mk5 => Mk5 General Area => Topic started by: m3cca on August 31, 2013, 12:40:04 am
Title: Edition 30 or R32
Post by: m3cca on August 31, 2013, 12:40:04 am
I am sure there have been a lot of threads in regards to this old argument.
But has anyone owned both?
Pros and cons of each and I guess experience in ownership, costs and servicing?
If anything like the TTs or the TT forum:
* R32 straight out of the box, more performance, smoother delivery and V6 noise.
* GTi, or Edition 30, more potential for greater performance, still a great car, but takes time and money to invest in it to make it greater performer. More bang for buck and return on investment.
Just would like to hear other people's thought and opinions, especially of those who have own both and which they preferred and why?
Thanks for sharing  :happy2:
Title: Re: Edition 30 or R32
Post by: adamm on August 31, 2013, 12:45:15 am
Test drove the MK5 R32 but decided to go for the Edition in the end. The R32 seemed to lack something. The MK4 R32 is much better IMO.
Post by: JackG on August 31, 2013, 01:03:54 am
More time and money too invest too make faster?  :signLOL:
A standard Eddie would do a R32....mine has
Then pay 299 for a map and the R32 would have too charge it too make it faster than a stage 1 Eddie.
400+ road tax too...and normally aspirated
Post by: m3cca on August 31, 2013, 08:19:20 am
Interesting a Mk4 R32 is better, I will have to investigate this, thanks  :happy2:
Post by: m3cca on August 31, 2013, 08:22:36 am
400+ for Road Tax?!?! I thought they were only £280! I am going to have to check this out and confirm, cause that will already sway me towards an Eddie!
I guess the V6 and the 4Motion are too heavy  :jumping:
Post by: simonp on August 31, 2013, 08:56:00 am
Nearer £500 these days, unless you go for an early one (55 or March 06 plate). I can only give you info on the R32, as I've never owned a GTI of any sort.
It's definitely not a car you can run on a budget. As stated already, the tax is something like £475 now and the insurance group is 18. My car averages around 24 mpg and will need filling twice a week if I do more than 300 miles in that period. It's not super fast, more of a cruiser than a hot hatch, but handles very well given the right tyres and an uprated rear ARB. Obvious plus points over a GTI are the noise and the traction.
If you want 300 bhp and a turbo kick, though, this ain't the car for you...
Post by: sub39h on August 31, 2013, 09:57:26 am
i think the earlier cars paid the lower tax. i'm not sure what year the cut off was. i've test driven an A3 and TT 3.2 and an Ed30 but never owned any of them. at the end of the day it's down to personal preference and only you can decide. both are quick out the box and neither of them are cheap to run (tho the Eddy will be slightly better on mpg and tax) but that shouldn't really sway you either way.
if it were me it would boil down to this:
if i planned on doing extensive mods (beyond a couple of suspension upgrades) then the Ed30 will give you far more bang for your buck
if you plan on pretty much leaving the car alone then i'd get the R32. it has more equipment as standard, is a bit more special in my opinion and sounds better
just a word of warning however, very early 3.2s had timing chain and ECU problems. as far as i'm aware these had been fixed by the time the R32 had been released, but i'd double check. additionally cars around MY07 with DSG may have mechatronics failures. this should have been repaired under a recall. this will affect both R32s and Ed30s. Ed30s have their own problems like cam follower wear, DV issues (less common than K03 cars), PCV but these are generally cheaper fixes.
Post by: flashp on August 31, 2013, 10:11:46 am
Don't forget that engine aside the Mk5 chassis is far better.
Didn't early Mk5 R32's get classified for the cheaper VED band?? £280 I think.
Post by: JackG on August 31, 2013, 10:44:13 am
couldn't have put it better myself...very good point :happy2:
Post by: shortdan14 on September 01, 2013, 06:08:57 pm
I own an edition30 and my dad used to own a mk5 r32.
If the r32 is pre April 06 it's the cheaper tax band at £250 or something but post that it is £450 or so.
I had this debate a while ago but decided on the gti after deliberation because I liked the fact it was an edition.
The r32 does sound beyond amazing though.
Oh and on a small point because of the rear diff the r32 boot is smaller.  :smiley:
Post by: Homer on September 01, 2013, 06:14:25 pm
The R32 from what I gather from current/previous owners is thirsty and not very fast. Is also difficult to tune apparently. I would stick to an ed30 but it really is down to personal preference I guess
Post by: R32UK on September 01, 2013, 07:23:11 pm
I have owned both.
I would still have my R32 over my old E30... its a personal thing. Lots would go for the Ed30, and if going fast in a straight line is what you want then that's what you should go for too.
Post by: simonp on September 01, 2013, 07:51:32 pm
                                         (in dry weather)
You missed a bit....
Post by: m3cca on September 02, 2013, 01:30:29 pm
I test drove a Mk1 TT Quattro 3.2, but the wife did not like the poor visibility and the practicality of it was poor. Wasn't a bad car, it was an '04 with around 55k on the clock, for less than £5k. Hell of a lot of car for that money. But alas, the wife's need to see traffic before changing lanes takes priority :)
Believe me about the practicality, I sat in the back during the test drive whilst she had a go, you need to be flexible!
From that drive and that sound of the v6, that is when I thought about either a R32 or an A3 with the same engine.
Thanks for clearing up the tax thing, as long as its before March 06, way cheaper tax, got it! We currently don't do that many miles, hence the only reason why I figure the v6 and its ability to turn petrol to noise, shouldn't make that much of an impact, although insurance is less than £100 more than a GTi/ED30 last time we checked.
For the time being whatever car, I would keep stock, hence just need to ensure the right spec, although I have seen clips of Millteck exhausts on an R32, very nice  :happy2:
Mods: Ed30
Stock: R32, if I can live with the higher cost of ownership and running costs.
Thanks for sharing, especially those who had the pleasure of running both!
Post by: Scottymon on September 02, 2013, 01:45:44 pm
Like that :signLOL:
The TFSI 4 pot sounds bloody awful, no matter how we wrap them up in CAI's/TBE's...
If your not doing the mileage, can get the lower tax bracket one and don't plan on modding the Ed.30 (as even stage 1 midrange would leave the R32) then why the heck not?  It's not all about the numbers, at least not for me. :happy2:
Post by: George on September 02, 2013, 03:30:13 pm
Had both, Edition 30 every time.
Post by: bigeyd on September 02, 2013, 03:35:03 pm
Stolen quote which made me smile as its possibly true
"ED30 is a competent car
R32 not the fastest car but its dripping in soul"
Post by: GrayMK5GTI on September 02, 2013, 03:56:44 pm
FWD is cool when your moving on a dry road and want to accelerate, 4WD puts every one of those 250 horses down every time, wet or dry with a great sound out of the exhaust  :notworthy:
If you want pub bragging figures and lots of torques, the Ed30 is for you  :happy2:
After going around the Nurburgring as a passenger in a mk5 R32, I'm very much in awe of how much grip they have
Better brakes too  :wink:
Post by: MAT ED30 on September 02, 2013, 03:56:51 pm
Had both but edition 30 hands down the better car
Post by: Christian1402 on September 03, 2013, 12:33:25 pm
Had a mk4 R32 and now have an ed30. R32 for me every time, not as fast no but such a better car on our UK roads. The running costs are higher but I never once got out of that car without a smile on my face. The ed30 even at stage 1 just doesn't do that for me, plus FWD sucks after being used to the Haldex system!
Post by: H17YD_L on September 03, 2013, 02:05:00 pm
R32 for the soundtrack, ED30 for everything else
Post by: MAT ED30 on September 03, 2013, 02:08:52 pm
Thing I hated about the mk4 was the seats they were just too bloody big for the car if you ask me I even toyed with getting another and pulling the seats out and dropping in some recaro pole positions as for me that would have made the car more enjoyable and less like being in an armchair
Post by: m3cca on September 03, 2013, 06:41:37 pm
Hey George, can you explain why?
Post by: Beddie on September 03, 2013, 08:12:21 pm
As an ex ed30 owner my advice is to buy whichever you like the most  :happy2:
Both great cars and asking which one to buy on any forum will only end up one way.... 6 page thread, an argument between the 2 most fanatic ed30 and R32 members and you still no wiser as to which car strangers on the Internet think you should buy...
