All Things Mk5 => Mk5 General Area => Topic started by: golfgti10 on September 27, 2013, 09:40:45 pm
Title: door card help???
Post by: golfgti10 on September 27, 2013, 09:40:45 pm
just took my door card off to fit the Passat buttons but can not get the lugs out, tried a coat hanger is there any where I can buy them new checked ebay cant find them as ill pull out the old and put in new
Title: Re: door card help???
Post by: skard on September 27, 2013, 09:43:40 pm
I use Y shaped plastic trim removers, cheap on ebay. You're best getting spare clips from a dealer though as some will probably break
Post by: golfgti10 on September 27, 2013, 10:33:41 pm
got a link to the tool also anywhere else I can buy apart from the dealer
Post by: MC71 on September 27, 2013, 10:48:09 pm
Clips from the dealer, TPS, eBay or Boldsport and a few more no doubt. Cost peanuts for loads of them.
Clip remover......
~~ Clicky here ~~ (http://www.ebay.co.uk/itm/Car-Door-Panel-Clip-Removal-Pliers-Sprung-Handle-/221184063786?pt=UK_Body_Shop_Supplies_Paint&hash=item337f98f92a)
Post by: golfgti10 on September 27, 2013, 11:01:19 pm
any of those can I order online and have posted from the uk
Post by: skard on September 28, 2013, 10:14:13 am
These look like aftermarket door clips
http://bit.ly/16ytUlM
Something like this is cheap and useful
http://bit.ly/16HVciw
Or sacrifice an old fork to make a V with a bit tape on to prevent scraping your door
Post by: sootpig on September 28, 2013, 10:23:59 am
There is no need to remove the cards :happy2:
 Those tools linked by SKARD are the way to go even when the ends become worn they can be fixed by a Stanley knife to give years of long service :happy2:
Post by: skard on September 28, 2013, 10:29:30 am
Haven't done them, but fuel flap switch means the drivers side should come off?
Post by: sootpig on September 28, 2013, 10:37:59 am
The fuel switch can be fitted without removing the card.I read about it on this forum so it must be true
 I did it myself  by creating a gap at the bottom of the door card and removing/refitting through the gap
 No broken bent clips as long as they are aligned before thumping the card back in place
Post by: MC71 on September 28, 2013, 11:25:08 am
^^*^ PITA with the door card on. Its still best to take the door card off (or at least release it from the door) when fitting the Fuel Flap switch.
