All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: T6 SUR on October 23, 2013, 10:42:14 am
Title: What Software version for RNS 510
Post by: T6 SUR on October 23, 2013, 10:42:14 am
Any help would be greatly appreciated.
I am on the look out for an RNS 510 unit.
I am just wondering what firmware version i should be on the look out for, i have a 2008 Mk5 GTI and want a simple plug and play unit without the hassle of updating anything.
many Thanks
Title: Re: What Software version for RNS 510
Post by: RetroRaz on October 23, 2013, 10:56:50 am
2760 or 3810 . Both need to be the modified version.
Post by: T6 SUR on October 23, 2013, 01:50:53 pm
thanks for that would do you mean though that it needs to be the modified version?
And can you confirm whether this is version B, C, L etc etc
Many Thanks
Post by: RetroRaz on October 23, 2013, 02:07:28 pm
The original versions of those firmwares would give you battery draining issues. You need the modified one to prevent battery from draining.
EDIT: just seen yo have a 2008 golf, Your canbus should be a newer version so any firmware will do
I have had 3 B units now and cant complain with them, If you go for a C or above, they will be LED and of course the price will also go up.
Whats your budget?, Ill see if i can source some for you..
Raz
Post by: T6 SUR on October 23, 2013, 02:18:00 pm
Raz
My budget is £350-400 max really,
thanks!
Post by: RetroRaz on October 23, 2013, 02:45:25 pm
Give me a few days, I see if I can get you one. My brother might be selling his soon.
Post by: T6 SUR on October 23, 2013, 02:48:09 pm
Thanks Raz
Post by: SkyJawa on October 23, 2013, 06:09:29 pm
Raz
Does this mean an RNS510 with modified firmware doesn't need the new gateway on a 2005 to stop the drain?
Title: Re: Re: Re: What Software version for RNS 510
Post by: RetroRaz on October 23, 2013, 06:45:26 pm
Raz
Yes.
Sent from my GT-I9300 using Tapatalk 2
Post by: SkyJawa on October 23, 2013, 07:02:13 pm
Now that's interesting thanks. Because that puts just a bit more expensive than and RCD510 and having to sort the new gateway as well.
Post by: micaerin on October 23, 2013, 10:57:30 pm
Anyone have a link for the modified 3810 firmware?
Thanks in advance :happy2:
Post by: SkyJawa on October 24, 2013, 01:59:31 pm
I'd be interested to know this too :) And also what the differences are between them, what features do you lose with the 2760 over the 3810?
Post by: SkyJawa on October 24, 2013, 02:11:34 pm
Scratch that, found it:
http://www.mk5golfgti.co.uk/forum/index.php/topic,23779.0.html
Does the VUCI update work on a C with the 4020?
Post by: RetroRaz on October 24, 2013, 02:16:00 pm
3810 is slightly more responsive, faster startup and a different startup logo.
