All Things Mk5 => How to Guides / Troubleshooting => Topic started by: Simon_2.0t on January 20, 2014, 11:08:33 am
Title: Fitting later 3D style boot handle
Post by: Simon_2.0t on January 20, 2014, 11:08:33 am
Hi guys, wonder if anyone can help or suggest how I can resolve this.
I am in talks with Simon (brookesb32) as the boot handle guru!  :notworthy: But we are still not sure how/why.
I have fitted a later 3D style boot handle to my 2005 golf to remove the whiteworm one. This sat flush but the new handle sticks out, looking at later 57 plate onwards golfs with this handle fitted as standard it sits flusher, and better than mine.
See pics below:
The handle in question. Standard one, not sure if missing anything around the base?
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Ftt323%2Fsimon_turbo%2FIMAG2695_zps71c2df32.jpg&hash=21deaa370fa7d49f947ad7ad9e528cdf4e0b5690)
Badge sticks out about 5mm:
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Ftt323%2Fsimon_turbo%2FIMAG2972_zpsee651ff6.jpg&hash=fe8c8c942750d694730a033a4287b1327c9081e8)
And from inside, the black locater is preventing me spacing the badge in further:"
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Ftt323%2Fsimon_turbo%2FIMAG2975_zpsa5a90fa2.jpg&hash=93c0e2bf3e8893a3f8f341cc8922548ca9456850)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Ftt323%2Fsimon_turbo%2FIMAG2973_zpsb861ead2.jpg&hash=154379709b52b9a67d9d57c94478b5b0c6f745a6)
Simon kindly send me some bolts from a later badge as well, cheers mate  :happy2: but still sits the same.
I thought about cutting the black tags off and then using some washers so the badge will sit more flush. Not ideal, plus think then will leak small amount of water in.
Hmmm. Maybe a later tailgate is different. if anyone has the rear trim off in the near future who has a 3D stype badge fitted as standard would they mine having a look how fits. Might have a shroud or trim bit I need.
Cheers Si
Title: Re: Fitting later 3D style boot handle
Post by: v4rley on January 20, 2014, 12:21:35 pm
I have a mk6 rvc badge, fitted to my 05 GTI and experience the same issue! I have just been living with it, as still looks better than the only white worn. Also looked at trying to space out with washer but no possible with the tabs. Not much help, but at least you know your not alone!
Post by: marko on January 20, 2014, 12:59:27 pm
you'll only start getting water ingress if you try spacing the badge in...hence why there is a tab or locator fitted
just have to live with it
Post by: Simon_2.0t on January 20, 2014, 01:20:15 pm
Cheers guys, are the tailgates different on 2007 Mk5 golfs?
Si
Post by: brookesb32 on January 20, 2014, 01:53:46 pm
Si
Yep we were both cofused on this one, my 55 plate did the same when I change the handle but another mates 56 plate was dead flush with his factory handle  :confused:
Post by: Simon_2.0t on January 20, 2014, 02:00:08 pm
Si
VW must have changed the tailgates Si. Odd but only conclusion.
Not sure if to go back to flush non 3D now...
Si
Post by: brookesb32 on January 20, 2014, 04:56:33 pm
Si
Si
Noooooo :)
Post by: JaseGti on January 20, 2014, 05:34:11 pm
Was thinking about doing my 05 with the mk6 badge but not sure now
Jase
Post by: Simon_2.0t on January 20, 2014, 06:17:11 pm
Si
Si
Noooooo :)
Think a Mk6 bsdge on this handle base will sit better? As I think they wrap round the edges more if that makes sense  :happy2:
Post by: brookesb32 on January 20, 2014, 06:41:00 pm
I can sell you a gloss black mk6 badge if you want one Si  :wink:
Post by: homesqueeze on January 20, 2014, 07:18:13 pm
Yeah mine sticks out like that too since I changed it on my '05. Still think it looks alright though.
Post by: G40will on January 20, 2014, 09:48:18 pm
I fitted a complete Mk6 handle to mine and it sits flush...
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Ff213%2Fwillg40%2Fa3d4ed8bec776eff02ee6223568df0f8.jpg&hash=7b5be6f794cc6c4c0680553025b86f53c39c0f48)
Mines a 2006, I'm not sure what year the badge was from though...
Post by: Simon_2.0t on January 21, 2014, 10:05:53 am
G40will, looks good mate. Is that a Mk6 badge on a 5 handle?
Si
Post by: G40will on January 21, 2014, 06:05:28 pm
Si
It's a full Mk6 handle and badge mate, had to stretch the wires a bit but it just about reached. I must lengthen them next time I take the trim of the inside if the boot.
The red in fills are pre cut vinyl of eBay for about £1.50 posted!
Post by: Luke s on January 21, 2014, 09:48:33 pm
 I've just fitted a mk6 badge to mine and it also sticks out. Tell me if I'm wrong but there are late mk5s with 3d badge and mk6 I believe mk6 is deeper I like it. G40Will if you trim the loom tape back where the lock wires and handle wires split there would be enough play to not need to stretch or lengthen them if you want to be anal like I was I re taped it with gen vw loom tape. Also would you be g40will from clubpolo? Used to go to the phirm red g40?
Luke
Post by: G40will on January 21, 2014, 10:33:07 pm
I did actually have a 3D slow close handle on mine before I fitted this one so maybe that's why? It must be a different design in the area the handle bolts too on the the lid itself.
I did trim the loop tape back a bit and loosen it all of to get it to plug in, It just fitted so is ok but I know it's not right so it bugs me a little.
Yes I was on clubpolo mate, had a GT and a couple of G40's then a CL :stupid: yeah used to hang around down there mate... Did I meet you down there at all?
Post by: Luke s on January 22, 2014, 05:41:00 am
Yeh I thought it was you i had a g40 conversion done by tim in a dragon green 6n polo
Luke
Post by: G40will on January 22, 2014, 08:53:19 am
Luke
Yes, I remember that! It had tonal turbos on it at some point?
Cool car man.
Post by: Simon_2.0t on January 22, 2014, 09:46:37 am
Funny how VW changed the boots on 2006 onwards.
If anyone has trim off at some point and has a 3D sytle handle fitted sitting flush be interesting in seeing what its like behind the trim. I'd imagine the same just a little deeper.
Si
Post by: Simon_2.0t on January 22, 2014, 09:52:03 am
Si
