All Things Mk5 => Mk5 General Area => Topic started by: sundance on January 30, 2014, 09:13:18 am
Title: Unable to unlock drivers door using remote first thing in the morning!
Post by: sundance on January 30, 2014, 09:13:18 am
Hey all
I have a weird problem with my 2006 Mk5 GTI which seems to have started with the recent cold weather - though not 100% sure if this was just coincidence...
Basically, typically first thing, I use the remote to unlock the car and it unlocks all the doors except the driver's door.  Sometimes if I press unlock a few more times the driver door eventually unlocks.   When it doesn't I have to use my key to manually unlock the door and that way I gain entry to the car.     :stupid:
What I've noticed is once I have done the steps above, I can once again unlock the car (including the driver's door!) until the next morning at least when the cycle starts again.   :fighting:
I have made no recent changes to the car.   Alarm is the standard factory fit and the only change made historically was about 2 years ago when it was recoded for 'single press unlock all doors' + 'auto-lock door when vehicle is in motion'.
Any ideas???
Ash
Title: Re: Unable to unlock drivers door using remote first thing in the morning!
Post by: Tortaruga on January 30, 2014, 09:34:43 am
It's your door lock control module acting up. It's a common issue and if you are so inclined there is a guide on how to replace the part here http://www.mk5golfgti.co.uk/forum/index.php/topic,52585.0.html
Post by: vRSAlex on January 30, 2014, 09:41:58 am
Get it replaced asap before it wont unlock, then you cant open the door to change the unit.
Post by: Tortaruga on January 30, 2014, 04:24:22 pm
No panic with a drivers door as you can use the key.
Post by: Pikey Motorsports on January 30, 2014, 05:04:28 pm
my s3 was doing this a few weeks back the odd time.. its been okay since though fingers crossed
Post by: rich83 on January 30, 2014, 05:18:46 pm
Seems to be effected by cold weather. Mines also intermittent fault on the drivers door. I'm happy to live with it until it breaks completely
Post by: Marc-5-GTI on January 30, 2014, 05:35:18 pm
Just got mine changed the other month because of this.
Get it changed, it's awful pressing the button loads when it's pi**ing down!
It doesn't break the bank either!
Post by: sundance on January 30, 2014, 06:11:33 pm
Thanks gentlemen.  What a brilliant forum this is  :happy2:
