All Things Mk5 => Modifications & Technical Area => Performance Modifications => Topic started by: chris-182 on February 20, 2014, 10:57:37 am
Hi all,
I'm new to the VAG scene and looking to get some lowering springs on my GTI.
What are peoples opinions on the Eibach sport lines compared to the H&R alternative. I'm not fussed on getting massive lows, just a better ride hight and to try and keep the comfort as close to OEM as possible.
Ideally I'd want around a 30mm drop
Cheers!
H&R go 30mm
Eibach go 20/25mm front/back
I have eibachs and I'm happy where they sit and how they ride
I have eibach sportline and very happy with them. Great comfort, has a good stance but isn't so low as to be unpractical.
I'm on H&R springs, went for these as I liked the drop more than the Eibachs.
Rides fine, only slightly harder than standard.
As far as I can see it's personal preference really.
Personally I prefer the stance and ride quality that the Eibach kit gives you over the H&Rs.
Damian @ DPM Performance
I'm the opposite. Find the Eibach drops the front more than the rear and gives it an odd look. The H&R is a nicer ride and is an even drop. Both are a well made spring.
Totally agree with Alex, defiantly a more even stance with the H&R's, slightly harder but great handling springs :happy2:
Cheers guys,
I think i'm going to get some H&Rs :) busy month as i will be getting a FMIC, GFB DV and a map also :)
Cheers guys,
Try this for a price on the springs http://www.mk5golfgti.co.uk/forum/index.php/topic,75129.45.html
brilliant! thanks!
Having driven in Manual and DSG gti's with both H&R's and also Eibach's fitted.
Personally, the Eibach's was a much better drive, smoother and absorbed bumps better.
As alex has pointed out, it does tend to lower the front more than the rear thou.
with the H&R's, I found the springs to not really be as forgiving as the Eibach or OEM.
Also uneven surfaces are more noticeable with H&R's fitted.
Even lowering thou.
Either way you go. The horrible factory rear bounce from the OEM springs on the highway are gone.
Actually, I have driven a car with APEX springs. It was by far the closest for lowering and bump absorbing as per OEM.
So for a cheap springs the APEX work very well.
If I had to choose between your 2 options I would always pick the eibach's over the H&R's.
100% happy with my H&R springs. Just the right amount of drop to make it handle better but not be so low you have to pussyfoot around.... And the ride is almost as comfortable as stock :happy2:
Happy with the drop and performance of my H&R springs too. As others have said they're lower than the Eibachs but not too low.
There you have it Rich, same answer from all H&R owners.
Eibach honestly drives nicer than stock 100% of the time.
So softer? More compliant?
It's hard to describe, but I guess more forgiving is the way I would answer it.
Eibach merely allows all coils in the springs to operate at the same time vs the H&R's starting at one coil and compresses to the next and the next etc.
Don't get me wrong, H&R's are still an improvement. Actually, any springs just about is an improvement over VW's factory rear bounciness of a car. :fighting:
:confused: :confused:
I ran H&R's for a year and agree with what RichWig says :happy2:
Slightly firmer than stock but not at all uncomfortable, which is exactly how a 200+ BHP hot hatch should feel. Anything more compliant than stock springs wouldn't inspire as much confidence IMHO.
Thanks Guys, i'm pretty sold on the H&Rs to be honest!
Its going in to the bodyshop next week while im in New York for a few minor touch ups, then once it is out it is booked in for Springs, FMIC, DV+ and a remap. Its going to be like a new car by the end of March. Cant Wait!!
Yeah that's what I thought :confused:
I have eibach sportlines and really like them. In normal daily cruising they are more comfortable than oem springs. They are not so crashy. Of course when pushing it, they firm up pretty quickly. I also like the stance, very nice and as low as I would like to go. I havent ridden in HR car, so cannot compare to those.
Some useful information in this thread, I'm sold on the Eibach
Don't think you'll be disappointed either way tbf
I nearly bought a set of apex springs but after reading how the Eibach work then It would seem there the best you can buy.
I've gone for H&R. will report back tomorrow :)
im fitting my H&Rs on Tuesday.
ill give my 2pence too when i get it back! :happy2:
Well the H&R's are now on, give a nice drop, but not too low.
The ride is just as good as oem if not better and the car feel much more stable in the twisties :)
I will get some photos added to my project thread at the weekend
might be a silly question but can you just change the h & R springs straight out for the factory ones? is this a better way of lowering your car instead of coil overs?
my H&R are on too and i find it a bit too low? (I'm still on my winters) so once i get my Pescaras back on it might look better! ill get some pics up tomorrow
handling wise, as above, just like OEM for ride... not had a chance to throw it anywhere yet as the winter tyres don't like it haha :grin:
yeah the H&Rs are are straight replacement for factory springs. it depends what you want, if you want to go quite low or use heavily on track then coilovers are the best option. if you want a subtle drop and to keep OEM comfort then springs are the way to go.
yeah probs down to being on your winters? mine are perfectly fine (on 18" monza 2s)
I've ran both an personally it's h&rs for me . I thought the eibachs still had the horrible bounce. The stance on the h&r was nicer as well but out on the limit the h&r,s far excelled .
Thanks mate, bit of a newbie to all this! I'll look into them, they much cheaper than coilovers?
H&Rs are under £200 and decent coilovers will be triple that price at least!
H&R get my vote... :happy2:
Won't putting springs on it just ruin your dampers?
Mixed opinions which ones should I buy
Confused.org
some pics of mine on H&Rs
Before:
(https://farm3.staticflickr.com/2872/13903744813_d97dd1025f_c.jpg)
After on winters:
(https://farm6.staticflickr.com/5123/13903450215_0d6a3f38ae_c.jpg)
After on 18" Pescaras:
(https://farm3.staticflickr.com/2917/13903466775_9478802cdc_c.jpg)
Sits totally different on the 18s, I'm well happy now it sits just right and rides perfect :happy2: :happy2:
Definitely recommend the H&Rs
Your car looks awesome. I wish I had black one aswell!
That does look pretty cool
Do you get any problems with speed humps?
H&Rs here & glad I went for them. Handling has improved & on decent roads no issues but even on 17" monzas speed bumps are quite firm IMO. Not crashy at all though & I'm pleased with the drop.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fimg.tapatalk.com%2Fd%2F14%2F04%2F18%2Fmyzypunu.jpg&hash=cc529491a223ff34110768c302fcca6c0fb79dcd)
cheers! :happy2:
ta! no problems with speed bumps! only minor scrape is coming out of our local petrol station where its a stupid angled slope joining another stupid angled sloped road!
^^^Aint there like 4 different types of H&R springs? What type do you have?
H&R GTI 30mm if you're asking me.
im guessing most people buy the 30mm h&r springs thats all i can find on sites like larkspeed etc
Just fitted Bilstein B4 Sport Dampers and Eibach Sportsline springs and very very happy with the result , car looks great and drives brilliantly. Although as mentioned somewhere earlier the rear is slightly higher.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fm601%2Fneilstt%2FP1020293_zps8c0a76ff.jpg&hash=0457cab02cc64d81560c96ee7aa033e9f4f66c5c)
I've got H&R's ready to go on next week.
I Phoned AKS tuning and got a really go price and fast delivery
I'm looking at buying some H&R for my ED30, they look low on the back do they rub at all?
And I'm getting some for my dads ed35 too haha! Any problems etc?
Jay
No they don't rub at all my ed 30 sits perfect and I've hardly noticed a different in ride comfort
This is the rears. It's more like 1 finger on a flat surface
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fsteven_hodgson1%2FMobile_Uploads%2Fimage_zps1ea2f89e.jpg&hash=30c989c1def4cdb056f9714ce943fd4ef10d071f)
Great ordering them today anyone who who's cheapest? Thanks again!
I got mine from AKS TUNING. There numbers here somewhere.
£170 I think they came too. Best I could find anyway
AKS tuning 01234 82 23 24
Just say your a member on here.
Okay thanks guys Alex can do them for £180 so that's fine just can't wait to get them fitted! Buzzing, how much is fitting usually?
Cheers guys!
Depends if you know a friendly mechanic. I paid £70
I got quoted 125 :(
That's still not bad the fronts where a bitch to remove on mine the top mount threads were rusty it's only a few years old.
Do they rub on the front at all? I just don't want to get them fitted and then they rub or doesn't fit properly! Anyone got anymore pics?
Naa they don't rub at all not even close. Just get them on you'll see
Do I need to replace the dampers or is it okay just put the H&R springs on ?
Most people just bang em on. Unless the shock is leaking or something.
Okay thanks mate :happy2:
Straight onto the original dampers is fine, but it will wear them out quicker.
How much are new dampers ?
Try here: http://www.eurocarparts.com
Thanks, will I still be able to bump up a curb with the H&R 30mm ?
^^^^ I wouldn't try it but if the kerb is very low, maybe.
My dampers are buggered... Bouncy bouncy bouncy. :sick:
I've just put H&Rs onto 68k mile dampers. Expecting to replace them by next year :sad1:
Anyone running H&R ultra lows?
Pill I definitely not be able to get up curbs on 30mm H&R ? As I need to bump up a curb to get into the drive :drool:
Kerbs are fine just go easy. I still fly over speedbumps.
Feel sorry for your car
You should get the council to lower it :happy2:
Ha ha I don't know why the wheels won't fall off. Clears them easily
I've just had VW put VW Racing lowering springs onto 74k dampers, doesn't feel bouncy but quite squeaky at times. Is this normal?
H&R all the way mine sits perfect with them and ride is fine :laugh:
Hi Neil C,
Love the stance and your motor Neil looking at your suspension set up and just wanted to see how your doing with daily driving, what's the ride quality like as I wanted the comfort to pretty similar to original but understand that it will be firmer? Which Eibach sportline coils did you go for as there are a couple of drops either 20mm front and back or 45mm front / 30mm back.
Any advice would be great
Marticroft :happy2:
Tbh I'm not 100% sold on the H&R springs. Wouldn't buy them again.
I have H&Rs on my Rocco and like the way it drives. Not any harder than standard springs really.
I didn't like the H&Rs on my Rocco. The DCC only really worked in sport afterwards. Comfort setting just didn't know what to do with itself :laugh:
@rich83 (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=709) What made you change your mind after 12 months?
I've have my H&R on for a few years now.. apart from them being about 5-10mm lower now than when first fitted I love them. Just the right about of stiffness / vs comfort for my taste.
I'm currently looking at changing my 85k old OEM dampers for Bilstein B8's and I'm hoping that doesn't firm it up too much more.
Because the rears are rusting already. Any ideas on what H&R warranty is?
just a bit of surface rust is surely normal on springs? I checked mine the other day while cleaning my brakes and arches and they had a couple of spots on them.
Not sure on the warranty but worth an email to them or whatever supplier you used surely to complain anyway if your not happy.
Do you think yours have "sagged" / dropped more since you've had them?
I'm very happy with my H&Rs, imo the ride is better than stock, no more crashing on the motorway and flat in the corners.
I'll hopefully be swapping them for BC Coilovers sometime this year.
No DCC on the facelift as standard any more. :happy2:
What Eibach spring set did you get as looking for the same drop? Looks the dogs gonads, how are the finding the drop to live with? Has the suspension dropped any further since you dropped her.
Marticroft
I have just fitted the Eibach Pro lowering springs to my Mk2 Leon.
The ride is still comfortable, the height has dropped by around 30mm and the stiffness has improved! Would recommend.
Mine is also dropped on Eibach Sportsline Springs and standard shocks - very nice ride, not crashy or harsh, I am very impressed
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fsdfordyce1978%2FGolf_GTI%2FIMG_1180_zpsbcac4139.jpg&hash=5a9a8233330cdc3730d4e57d631631a44cbdf8fd)
I have Eibach Sportlines with Bilstein Sprint shocks on my GTI and can also say that the rear end does sit higher than the front. I also replaced a fair amount of bushings while upgrading springs and shocks so I can only speak for the operation as a whole but the chassis does feel very solid and it does ride alright too despite the Bilsteins. The controlled rebound with the Bilsteins in higher speeds is just lovely though... :driver:
I am not totally convinced with the Eibach springs however as they don't give the stance I wanted to and I feel they are causing a little bit of flightyness at the rear end that my car didn't have with the stock setup. Of course I can't say whether it is the springs or shocks that is causing this as I changed them at the same time. Nonetheless, I already have acquired a set of H&R springs and will soon be swapping my Sportlines for the H&R's so I can then report how the lowering and handling is between the springs with the same Bilstein shock!
Here's a pic of my car how it stands with the Sportlines:
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fs193%2Flateman_2007%2FWP_20140501_001_zps3303a9e2.jpg&hash=82fafab6db89246d6e26bbc4b3b22b5b65abf12d)
Cheers guys you've all been a fantastic help... Ended up going for the sportlines...really impressed with the stance and ride
Marticroft
Does anyone know if there is a different kit for the H&R for DSG's or if its the same kit regardless of manual/DSG?
There's only one part number for GTI, 29176-1, so it's the same for both manual and DSG.
Hi Stuf,
sorry for the delayed reponse... Ended up going for the sportlines and replacing the front shocks for Bilstein the ride is firm but forgiving and clears all speed bumps as I wanted. The only problem which is doing my nut in is the since changing the springs a spring squeak has developed and not sure what to do next. And advice would be greatly appreciated guys.
Hi Hevoshullu,
Your stance looks really good from the photo but I know what you mean with the rear being a bit higher. How's the H&R's looking?
Thanks, actually I have booked a time to my local garage to swap the Sportlines to the H&R's for next tuesday so we will know soon! : ) I can then give an opinion how they compare in terms of handling and comfort as well, as nothing else in my car will change.
How is your stance on the Sportlines? Is it level or does the rear also sit a bit higher? As far as I remember, mine used to be spot on right after the install but then the front settled down a little so in the end the rear was left a bit too high.
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fimages.tapatalk-cdn.com%2F15%2F07%2F16%2F5b1a063197a18d2cbfcfa3fc0b3a086b.jpg&hash=12f2a45fcee5956f8e1089b5000a074389e2ed54)(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fimages.tapatalk-cdn.com%2F15%2F07%2F16%2F0a9a2ff0d1fb0c7fa1b09dc26bed8f27.jpg&hash=d1cde58eb08d6e832d85392b53fa681ec5d0385f)
Looks really good that, think I need 18s!
Cheers m8 .. The only thing that's doing my nut in is the engine cover is knackered (mounts busted) new costs an arm and leg and the eibach sport line suspension squeak. Any advice would be great as wearing me down now
M
I'd be after sportlines aslo, had them in my civic and they were brilliant. Haven't driven a car that handled better than that in a long time! (Excluding my current E92)
I just swapped my Sportlines to the H&R (part 29176-1) because I wasnt happy with the forward rake with the Sportlines (ie. rear was higher). From what I've seen in pictures from other H&R owners' cars the lowering seemed spot on, a little lower than Sportlines with a neutral stance. However, at least initially, the drop on my H&R's was a bit of a disappointment. I would say the car is now actually around 10mm higher than on my previous springs, the Sportlines. I know you need to let the springs "settle" to reveal the final stance but right now there is quite a lot to be settled so I am a bit skeptical. Has anyone else had similar experiences with the H&R's - that they will actually settle down a good amount after the first few hundred miles? I will put up a picture after I've let them settle for a few days and got some miles on them too.
They will settle, just ask @rich83 (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=709). :wink:
I'm in the same process, my mechanic just fitted the H&R springs and new Koni Sport dampers. I had Sportlines fitted before.
Yeah they do settle.... Cant say that I am that impressed with the H&R springs to be honest. The rear ones IMO are not very well designed.
Because of the rust or for another reason? :confused:
Yeah that and the fact that half the coils sit on each other.
Do they squeak over bumps?
I noticed the same thing. I wouldn't say it's half the coils that are sitting on each other on mine, but a couple at least are even when the car is unloaded. I guess it's not a design fault as a suspension doesn't just compress but also works in the other direction (ie. droop). Also, they don't squeak on mine.
I have my fingers crossed that the my H&R's will settle at least 10mm. :happy2:
No
I took my GTI for a drive on local country lanes to test out my new H&R springs. Having just switched my Sportlines for the H&R the result wasn't quite what I expected. From what I read here I thought the H&R's would be lower and harder than the Sportlines but it was actually the opposite for me. The differences are subtle but noticable, the H&R are definitely the nicer and more compliant spring as far as the initial travel goes. In harder cornering they are properly stiff just like the Sportlines - I guess this is thanks to the progressive design.
I have to say I am impressed how the H&R's handle with Bilstein B8 dampers and Asymmetric 2 tyres. The car now has a lovely suppleness to it (which also means more grip on slightly bumpy roads that we have here in Finland) and the whole chassis/tyre combination has this progressive nature to it when you push the car. I wouldn't say my car lost any feel when switching from Sportlines to H&R's but what I don't like is that after the first 100 miles the H&R's are still sitting noticably higher than my previous Sporlines.. I will measure the exact distance from top of the wheel arch to the center of the wheel after a week or so. On the Sportlines it used to be 335mm front and rear (for some reason the rear still looked like it sat higher with those). I have a feeling on the H&R's it is now a whole 10mm higher at least which is really disappointing because that makes a world of difference to how aggressive the car looks.
All in all very happy with how my car feels with H&R springs, B8 dampers and Asymmetric 2 tyres. Still can't wait to get some Michelin PSS under my GTI. Must also add that damn she handles beautifully for an old bird that she is at 8 year's age. : )
More travel would equal more suppleness, you have to compromise somewhere
Just measured the gap from the top of the wheel arch to the center of the wheel after having driven a couple hundred miles on my H&R's. It's 340mm front and back so slightly higher than my previous Sportlines that were 335mm front and back. Can anyone else measure their gap with H&R's just for comparison out of curiosity? My car is a regular mk5 2 door GTI with manual so from the lighter end of scale what the GTI's can be, I suppose. I am also running on Bilstein B8 dampers which might affect the ride height?
Dampers should not effect ride height at all.
Fitted sportlines on new oem shocks, the ride is really harsh! Do you think they will bed in?
I don't think they will. They're mismatched and won't change. Well actually they might...when the stiffer shorter spring has punished the damper into an early grave.
My thoughts are buy this equipment as matched sets, whichever you buy. For example, B12 kit has matched spring and damper rates and the valving is engineered to match the combination. They spent a lot money and resource getting it right, I couldn't do better by trawling the forums touting for opinions on combinations.
Same goes for ARB's as well.
I know what you're saying but the budget doesn't stretch at the moment! They have actually softened a little, dampers were probably in storage somewhere
Watching this thread with interest...I think I want some Eibachs...no, some H&Rs...Oh I don't know...
Dave
Dave
Lower the drivers seat... Load the car with a few people and there's your lowered Ride... Sorted :wink:
That increases fuel consumption. :signLOL:
I had h&r on my last ed30 and plan on doing the same for my new that I got last week :)
Sent from my SM-G920F using Tapatalk
I had H&R springs and standard shocks for about 4 yrs and I personally thought they were one of the best mods I ever did.
They performed great on the road and coped pretty well on track too.
As for the look? The drop was great and I never had any issues with rubbing on the arches. (As long as you do the arch screw delete)
Anyway here are a few pics showing the different wheels I had. All these were with the H&R lowering springs. :wink:
Standard Pescara… 18x7.5J ET51 with 225/40/R18 tyres
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Ftt210%2Fmonte0797%2FT14.jpg&hash=ff6153cf1e4869303447bb925265bd9d2e8566c8)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Ftt210%2Fmonte0797%2FT0G_0723_HR-1-1.jpg&hash=c5f6aaef19d50c03edd0f499af52d8ce8df3c303)
Same as above but Powder coated Satin Black… 18x7.5J ET51 with 225/40/R18 tyres
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Ftt210%2Fmonte0797%2FP1060675.jpg&hash=c3fc5957356d9f11621e7afab36ea8f349cfdd53)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Ftt210%2Fmonte0797%2FP1060683.jpg&hash=37c9ffcbdb34a4695ed0b52066a042700361b65f)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Ftt210%2Fmonte0797%2FP1060678.jpg&hash=a814dc180b3e505e4d9c4a9068a6972b914dd4b3)
MTM Bimoto Reps… 18x8.5J ET45 with 225/40/R18 tyres
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Ftt210%2Fmonte0797%2FP1060608.jpg&hash=bd38ab9e44fc7afd78a29108999813db98b81386)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Ftt210%2Fmonte0797%2FP1060621.jpg&hash=f5e624afec810cedd180a0b6764734c63b146423)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Ftt210%2Fmonte0797%2FP1060613.jpg&hash=bd929d95e5728a29721b0504cc24e63c8e7b6739)
19"Monza's… 19x8J ET45 with 225/35/R19 tyres
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Ftt210%2Fmonte0797%2FIMG_5400_1024x768.jpg&hash=750409fe15b7719cee846b8a762433ebb8152a30)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Ftt210%2Fmonte0797%2FIMG_5410_1024x768.jpg&hash=b8e496560283b15fe5693f911ac9246d2562beae)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Ftt210%2Fmonte0797%2FIMG_0473.jpg&hash=81b91a1187e8f273831db93531e115d28bdca2fa)
19"OZ Ultralegerra's… 19x8J ET45 with 225/35/R19 tyres
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Ftt210%2Fmonte0797%2FIMG_0565.jpg&hash=5a1ead28e61242f953585d87fccc7633470057ef)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Ftt210%2Fmonte0797%2FIMG_0575.jpg&hash=005ac50432f4d9170e5f626a4d4d22270dc54e1d)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Ftt210%2Fmonte0797%2FIMG_0572.jpg&hash=ca41a1536c2595d434e2cd556b4baaf9b7635f7e)
19" BBS CKs 19x8J ET44
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Ftt210%2Fmonte0797%2Fnull-90.jpg&hash=e3f6f1b8151c7f7661bbd35ff51a74b8f58981a1)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Ftt210%2Fmonte0797%2Fnull-89.jpg&hash=9809b058ca11c9288849abd57d190b35712aa6ae)
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Ftt210%2Fmonte0797%2Fnull-88.jpg&hash=6b0fbd8cd7481624fc2c9a3f440b3d9753014413)
Those 19 monzas look amazing
All of them look amazing, to be fair. Just the MTM Bimoto would look better if they were genuine and 19''. :drool:
I just think the Monzas really suit golfs
Yeah the 19" Monzas were really special wheels. Rare Italian made ones that were better quality than the 18" Ronal/BBS ones from VW.
19" Bimotos are awesome yeah...tbh the 18" versions I had were ok but I soon lost all interest for 18's
Got to be 19" wheels on a mk5 :wink:
I only use 18" wheels on the track and they are anthracite TD PR1.2s :driver:
Just ordered H&R for mine!
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fimages.tapatalk-cdn.com%2F15%2F09%2F05%2F62395f3aa5f5a8bde61b8c8452e1be91.jpg&hash=31fc8b764a68496230eccee11c62e918d241dbef)
Got my H&R springs at the ready!
are people still worried these are going to rub??? :confused:
had my H&R springs done about well over a year ago on standard springs and they are still doing the job nicely.
Same as my Eibach SportLines fitted to standard shocks (which have done 172,000miles) - nice compliant ride!
Even the wife is happy which is a win for me! :happy2:
Sorry if this has been mentioned on this thread before, I did have a quick look but didn't see it... I'm ordering myself some H&R s tonight or tomorow, is there a best place to buy from regarding price etc? I've seen them around the £180 range but thought it might be worth asking incase someone knows of cheaper??
I paid around £145 and got them delivered from Germany. Took 3 days
Yeah I got mine on ebay.de too (German eBay)
Mine were £135 delivered, and took 3days too. :happy2:
I did buy mine in 2009/2010 though so price may have changed.
Just checked and it was actually £138 :)
Cheers guys :happy2:
Do h&r do different springs for dsg and manual cars as the dsg had a heavier front end?
Yes.
Can you tell me if these are dsg ir manual springs?
http://m.ebay.co.uk/itm/H-R-LOWERING-SPORTS-SPRINGS-Golf-Mk5-Hatchback-2-0-GTI-2004-2011-30m-H-R-GERMANY-/191692425239?nav=SEARCH
Judging by the part number - 29176 - they're manual.
That's great thanks
I don't think it's matter if is Dsg or not.only if is awd or fwd.dsg weights 40kg more is not that much of difference.I know cause when i did my awd swap the eibach spings my car has as fwd dsg lowered another 2cm especialy in the rear.if you look in H&R site you will find it out
Στάλθηκε από το SM-G920F μου χρησιμοποιώντας Tapatalk
Eibach has different part numbers for DSG and Manual gearboxes. H&R only has one part number for GTI. :wink:
I got mine from this ebay shop: http://www.ebay.co.uk/itm/190661536525 (http://www.ebay.co.uk/itm/190661536525).
+1 for H&R by me!!!
These H&R springs are superb for the money and work really well with stock dampers and a anti lift kit.
I've had two sets of KW Clubsports at £2k a pop on two of my sat ED30's and for value the H&R are pretty good value......I expect even stiffer on harder dampers such as Bilstein
Iv bought a set of the h&r springs now and as my shocks e 97k old I'm going to pair them up with a new set of bilstein b4 dampers, same as the stock dampers just suited for lowered cars, hopefully be an ok setup for the money
Check your facts straight. Bilstein B4 aren't sport dampers, they're just normal dampers. B6 are sport dampers for normal springs. B8 are what you should have brought since they're for lowering springs. So, don't be surprised if your dampers don't last what you expected them to. :happy2:
Ahh I have been told they are suited to going as low as 40mm without any issues, would I be better off with bilstein b4 or new factory shocks then?
OEM dampers are sport, so similar to B6. B8 are the ones for H&R springs.
Cant afford a b8 setup, so better just getting oem dampers?
In that case, I guess the OEM are better suited. They will be set for a sport setup while the B4 are more comfortable and not for sport springs.
Bugger it, endded up coughing up the extra cash for the b8's :party:
In the long run it was the wiser decision to make. Everyone here praises them. :happy2:
Hope you got the B8s from the same seller as me. I save about £300.
My car sits quite unevenly on all 4 and I'm not sure if eibachs would sort that out as they lower the front more?? If I do get them, which shocks do I get as I don't want a very firm ride?
It's a 1.6 FSI
It's a 1.6 FSI
You might have the dampers not evenly "dead". These springs "kill" OEM dampers much more rapidly. If you still have your OEM dampers from your 1.6 FSI, your dampers aren't as prepared for the springs as the GTI dampers are (-20 mm drop from normal suspension).
For these springs you need Bilstein B8, Koni Sport, or other with similar specs.
Konis are sold with H&R springs as suspension kits while Bilsteins are sold with Eibach springs.
Konis: http://www.koni.uk.com/home/index.php?option=com_content&view=article&id=253&Itemid=284 (http://www.koni.uk.com/home/index.php?option=com_content&view=article&id=253&Itemid=284)
Bilsteins: http://www.bilstein.de/en-uk/products/sport-and-threaded-ride-high-adjustable-kits/bilstein-b12-sportline/ (http://www.bilstein.de/en-uk/products/sport-and-threaded-ride-high-adjustable-kits/bilstein-b12-sportline/)
@shoduchi I've got standard springs and shocks atm and they need to be changed soon so B8s and sportlines it might be!
Do the sportlines drop a gti by 50mm? If that's the case then I'd have to go for the pro kit wouldn't I?
Appreciate the help mate
A GTI is already lowered from factory 20 mm, Eibach Sportlines drop another 25-30 mm. It's noticeable that the rear is not as lowered as the front. You can see on my Ed. 30 pictures of Sportlines with OEM dampers. I've recently fitted Koni Sport with H&R Sport springs and shared a few pictures with them still new, so they'll drop at least 5-10 mm more in the future.
Carparts-baust?? Bybfar the cheapest iv ever seen them
Yep. That's them. :happy2:
Just noticed I was the link u put in the wanted secition that I found them haha, cheers :drinking:
I've read somewhere h and r do a 30mm and 50mm Spring is this true?
Also best dampers to match up to the h and r springs? Seen the b8s mentioned but arnt they abit pricey?
H&R does that for normal Golfs, you only have the -30 mm for the GTI because GTI are already -20 mm from factory. :happy2:
The normal -30 mm H&R springs are black and equivalent to Eibach Pro-Kits. The normal -50 mm springs are red. Ours are blue and the same as the red. :smiley:
In the USA you have different options.
I'm still confused mate haha
What are my h and r options for a gti then? Just 30mm
I think H&R do do a 30mm and a lower one... I think they are called "super sport"
That's in the USA. In Europe there's only one option in the catalogue. :smiley:
H&R are german so it would stand to reason that you could get them.
Yeah, you can. At least who supplied my sway bars said he could get stuff sold in the USA. You can ask AKS Tuning, for example.
Just a quick query
I've got H&R 30mm springs on my ED30 with OE shocks....a very nice combo for road use.
I' m toying at doing the shocks for some more control on damping when I take her on track occasionally next year.
Are the Koni Sport dampers as comfy as the Bilstein B8 with these springs?
I had KW Clubsports on two previous ED30's and they were brilliant and very comfy and you could really wind them up when needed....,.costly though.
The B8 dampers are £600 on their own.
Any pointers for best deals on both makes?
Or do I bite the bullet with KW's again ?
I like my Koni Sports with H&R -30 mm. They're comfy enough for me. I don't know how the B8 would be like so I can't comment.
If you know the KW Clubsports are what you really like and you can't get any GTI with the other suspension options to try out, I'd go for the KW.
My Koni Sports cost 464,40 €, much cheaper that that price you mentioned for the Bilstein B8. I think you can get the B8 from Germany cheaper than £ 600. Around 500-550 €, maybe.
