All Things Mk5 => Mk5 General Area => Topic started by: 18Edition30 on February 20, 2014, 08:09:25 pm
http://www.opieoils.co.uk/product-finder.aspx?CategoryID=87&ProductTypeID=80&SEName=brembo-brake-discs#results
I thought the rears were 260mm?
All I see on here is 256 and 282.
Help guys!
282mm used to be 286mm either will work
On GSF it says 260mm is right for my reg?
So either of the 280s will be fine?
Cheers!
Listen to the man ^^! /endthread
I know I know. Just like to be sure! Now.....
Pads to match
105.5mm wide
Or
87mm wide...I'm presuming the bigger ones?
Cheers DaveB
I had the same problem on the website for fronts and rears and gave up
Will go to local Parts place so if they are wrong i can take them back !
Never known so many combinations for a mk5 golf!
Help me out guys!
Sorted the discs as stated by Daveb.......just need pads confirmed!
Any info on pads? Daveb?!
You've got me thinking now, I bought some pads today for the rear and told the guy my gti had 286 rear discs on as my reg on the computer said it didn't exist :scared: anyways if I have 282 dics will I have the wrong pads or are the pad all the same for what ever rear disc you have on the gti.?
wider ones are for the RS4 7 A4s and A6s
Narrow ones for Mk5 platform
Mk6 which has the 260mm rear disc has a bosch caliper which uses a different pad. Mk5 GTI / Eddy pads uses the lucas TRW caliper
