All Things Mk5 => How to Guides / Troubleshooting => Topic started by: boarderianb on February 25, 2014, 09:25:53 pm
Title: 07 gt tdi intermittent tappet like noise help please
Post by: boarderianb on February 25, 2014, 09:25:53 pm
I have an intermittent tappet like noise can go days without anything then comes on hot or cold if I go over a big bump in road sometimes goes again sounds loud like old diesel car strange
Ideas anyone
Title: Re: 07 gt tdi intermittent tappet like noise help please
Post by: sean76 on February 27, 2014, 12:38:00 pm
Bump  :P can anybody help monkey boy here please coz it's driving him mad  :stupid:
Post by: Zseth on February 27, 2014, 03:36:32 pm
i would suspect it is your fuel lines knocking against the chassis.  Quite common and an easy fix, search on here to find thread
Post by: doylebros on February 27, 2014, 04:41:44 pm
No knocking fuel lines on 07 GT  TDI - yes on GTI that would be a good shout!
If your saying it's an engine noise my money would be a faulty injector for the symptoms you've described hot or cold or the tank fuel pump beginning to fail!
Post by: boarderianb on February 28, 2014, 10:06:02 pm
Cheers will look into it asap
Post by: S4nup on March 01, 2014, 05:56:45 am
Had similar issue, turned out to be a worn belt tensioner.
Post by: boarderianb on March 02, 2014, 06:12:56 pm
Had belt and tensioners done last year could it be this already ?
Post by: S4nup on March 02, 2014, 06:18:31 pm
Get your alternator clutch pulley checked. I have a similar issue where I had replaced the tensioner and belt, but the noise came back 7-8months later. Realised that the clutch pulley was jammed. This causes extra stress on the tensioner pulley and causes it to wear prematurely. For me the sound is a very pronounced intermittent tappett noise in the cabin. Kinda subsides in neutral and under a little load
Post by: boarderianb on March 04, 2014, 11:39:58 pm
ok so i looked at the alternator puey today could see any probs there  ?
no noise for a few days then back today eeeergh driving me crazy
