All Things Mk5 => Modifications & Technical Area => Performance Modifications => Topic started by: G4SYU on March 07, 2014, 01:17:53 am
got a 5 door mk5 gti with a audi s3 engine. i was told to get it remapped to a stage one so the gearbox and engine is balanced, so i have done that. what else would i have to do to keep the running smoothly and faster……
I dont understand what you have done there?? :stupid:
You remap a car to get some power, make it do faster etc. . .
You would need a new map as you probably went from a standard gti engine ko3 to a cdl ko4 with the standard ecu remaining??
what i meant to say is that , i want it to perform better without mapping it any more , any other touches i should add.
This makes no sense at all.... Do some research buddy... If you have a S3 engine you will need to have gti ecu remapped to make it run correctly?
yeah thats done ..
