All Things Mk5 => Mk5 General Area => Topic started by: vag12 on March 20, 2014, 12:24:43 pm
Last night I was having bad misfires so took it to garage this morning to change plugs, but frm cylinder 3 the plug had oil at the bottom of it? What can this mean and also since changing plugs I have white smoke coming out of my exhaust? Any idea what it could be?
Most likely PCV valve..common issue, or valve cover gasket...
PCV is blanked of so out of question, valve cover gasket was changed yesterday still the same
Ok..so white smoke indicates that the coolant is beign burned...might be tge head gasket.. try compression test..
Was it just oil or was the plug very sooty too? If so might check fuel injectors too.
Not sure if it's the same, But on my TSI engine, i had the exact same & i needed to have the gasket seal re done.
Apparently on a TSI it wasn't that straightforward to done and half the engine had to be took apart. :signLOL:
White smoke tends to mean water getting into the cylinder - could be head gasket.
Blue smoke tends to be oil burning off.
If you have white smoke and oil on the plug, it points to a head gasket failure.
I hope not but best to get it checked.
Have you got oil in the coolant water? It might only appear as a trace on the surface.
