All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: xonk on March 31, 2014, 12:28:02 pm
Hi,
Just picked up an RCD 510 from a friend and have a 2005 GTI. After reading on the forum I see i also need an upgraded CAN bus. Do you know where the best place to pick one of these up? I just missed one in the for sale section I believe.
thanks
I've got one for sale :happy2:
http://www.mk5golfgti.co.uk/forum/index.php/topic,80800.0.html
OK great that was quick, is there any programming needed or should it be plug and play
can you pm me details,
You will need to program the Gateway using VCDS. If you don't have VCDS, you can locate your nearest friendly forum member here - http://www.mk5golfgti.co.uk/forum/index.php/topic,120.0.html (http://www.mk5golfgti.co.uk/forum/index.php/topic,120.0.html)
thanks for the info, a big list but nobody near Dublin, I see the cable is not that cheap either!
if the Radio came from a similar car would this work or would it require details of mine via VCDS to work?
My advice would be to speak with Eddie-NL as he can provide pre coded Gateways meaning it will be plug and play :smiley:
his contact details , you need to post one more reply before you can private message
http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=2345
Brilliant, thanks for all the advice
