All Things Mk5 => Modifications & Technical Area => Sat Nav and Car Audio => Topic started by: TaylorGTi on May 31, 2014, 08:44:54 pm
Title: Rns 510 in 56 plate gti
Post by: TaylorGTi on May 31, 2014, 08:44:54 pm
Iv heard I need a can gateway if I install the rns510 satnav is this true cheers
Title: Re: Rns 510 in 56 plate gti
Post by: skard on May 31, 2014, 08:55:35 pm
The safe answer is yes you'll need a new gateway. However, as 56 plates were into March 2007 you may have the non battery drain variant of a K version gateway, or even an L. Only way is to check or have it scanned with VCDS
Post by: TaylorGTi on May 31, 2014, 09:15:07 pm
Can you fit gateways yourself?
Post by: Eddie-NL on May 31, 2014, 09:17:20 pm
I can offer new pre-coded gateways for £75 delivered
Post by: Shaw on May 31, 2014, 09:23:28 pm
Mine is an '07 and suffered battery drain. :(
Post by: Little_Dave on May 31, 2014, 09:26:57 pm
Depends.... I had an rns510 on my 54 plate with a modified firmware and never had an issue with battery drain, depends where you get the unit from and if it can be changed over or wound back so to speak  :happy2:
Post by: doylebros on May 31, 2014, 09:51:52 pm
This is worth a read
http://www.mk5golfgti.co.uk/forum/index.php/topic,47405.msg589543.html#msg589543
Post by: downsideup on June 01, 2014, 07:14:54 am
This apparently is a modified version of the 4020 firmware for units with battery drain issues
I installed it on my 07 with L gateway and it worked a treat.
http://www.rnsfirmware.com/firmware-4020-for-older-units-in-europe-with-hdd-rations-60355/
After stick v10 maps on.
Post by: skard on June 01, 2014, 10:04:48 am
^^I have that and I thought the only modification was to change the disk partitioning percentage?
You have an L unit so nothing to worry about.
Post by: Degudodger on June 01, 2014, 11:31:47 am
For the sake of what EDDIE-NL charges for a coded Gateway i would replace it as you then have the flexibility if you decide to upgrade the firmware at a later date.
Post by: Viking on June 01, 2014, 11:36:55 am
Yep, doesn't modify for battery drain.  :happy2:
Post by: Eddie-NL on June 01, 2014, 12:04:35 pm
and when you sell the car you can swop back to the original gateway. And sell the newer gateway
