All Things Mk5 => Mk5 General Area => Topic started by: PhilGeezer on August 24, 2014, 08:19:31 pm
My fk coilovers should be here next week and im just wondering if i need short droplinks or adjustable droplinks?
i dont want to get so far in fitting and then realise i need them :scared:
i intend to go as low as i possibly can, if that makes a difference
any advice or experience would be greatly appreciated :happy2:
cheers
I would advise slightly shorter drop links, adjustable are the best as you can adjust them so there is 0 preload on the anti roll bar, as thats the last thing you want!
My FK coilovers come with shorter drop links any way, so with a bit of luck yours should too
Yeah they should of come with droplinks but apparently they got sent a batch without them and had none in stock :sad1:
I wouldn't worry to much, I had some jom's on mine for about 7 months with standard drop links and never had a problem
Spot on :happy2:
Ill see how i get on without them and can always get them at a later date if necessary
cheers bud
