All Things Mk5 => Mk5 General Area => Topic started by: ibbyem on October 07, 2014, 10:33:07 am
Title: Gti in limp mode and a few codes
Post by: ibbyem on October 07, 2014, 10:33:07 am
Hi everyone I'm new to this, hope everyone's well :) just need some help/advice
I think my car is now in limp mode doesnt rev over 4000 RPM and has no turbo kicking in, after doing some research i found out it is in limp mode
after connecting a vagcom to the car i came across all these faults
need help with this ASAP
Monday,06,October,2014,16:14:03:62939
VCDS Version: Release 12.12.0 (x64)
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Control Module Part Number: 1K0 907 115 Q HW: 8P0 907 115 B
Component and/or Version: 2.0l R4/4V TFSI 0010
Software Coding: 0403000318070160
Work Shop Code: WSC 01279 785 00200
VCID: 3467FA5B57CEB4BE40B-8061
6 Faults Found:
012691 - Intake Manifold Runner Control
P3193 - 002 - Open Stop outside of Valid Range
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 104887 km
Time Indication: 0
Date: 2000.00.00
Time: 23:16:26
Freeze Frame:
RPM: 1077 /min
Load: 23.1 %
Speed: 0.0 km/h
Temperature: 76.0°C
Temperature: 24.0°C
Absolute Pres.: 980.0 mbar
Voltage: 14.097 V
004248 - Intake Manifold Tuning Valve Position Sensor (G336)
P1098 - 001 - Open or Short to Plus
Freeze Frame:
Fault Status: 01100001
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 104887 km
Time Indication: 0
Date: 2000.00.00
Time: 23:16:26
Freeze Frame:
RPM: 1041 /min
Load: 23.9 %
Speed: 0.0 km/h
Temperature: 76.0°C
Temperature: 24.0°C
Voltage: 13.970 V
012423 - Voltage Supply Relay for Engine Components
P3087 - 002 - Electrical Malfunction
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 104887 km
Time Indication: 0
Date: 2000.00.00
Time: 23:16:26
Freeze Frame:
RPM: 1018 /min
Load: 23.9 %
Speed: 0.0 km/h
Temperature: 76.0°C
Temperature: 24.0°C
Voltage: 14.097 V
008853 - Fuel Pressure Regulator Valve (N276)
P2295 - 002 - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 104887 km
Time Indication: 0
Date: 2000.00.00
Time: 23:16:26
Freeze Frame:
RPM: 997 /min
Load: 23.5 %
Speed: 0.0 km/h
Temperature: 76.0°C
Temperature: 24.0°C
Voltage: 13.970 V
001112 - Evap System Purge Control Valve (N80)
P0458 - 002 - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 104887 km
Time Indication: 0
Date: 2000.00.00
Time: 23:16:27
Freeze Frame:
RPM: 997 /min
Load: 23.5 %
Speed: 0.0 km/h
Temperature: 76.0°C
Temperature: 24.0°C
Voltage: 13.970 V
000581 - Solenoid Valve for Boost Pressure Control (N75)
P0245 - 002 - Short to Ground
Freeze Frame:
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 104887 km
Time Indication: 0
Date: 2000.00.00
Time: 23:16:27
Freeze Frame:
RPM: 997 /min
Load: 23.5 %
Speed: 0.0 km/h
Temperature: 76.0°C
Temperature: 24.0°C
Voltage: 14.097 V
Readiness: 0110 0101
