All Things Mk5 => How to Guides / Troubleshooting => Topic started by: AndyBrown on November 23, 2014, 06:24:18 pm
Evening,
I get an intermittant fault on my 57 ED30. The engine management light comes on now and again, it goes off when the battery is disconnected.
Had it scanned tonight and there was a few codes coming up, Cooper the lad who done it said they could all be connected.
Theres no obvious symptoms with the car although I have noticed it can be a bit rough on idle once the cars stopped and out of gear (DSG)
Heres what we got from VCDS if anyone has any ideas.
5 Faults Found:
008583 - Bank 1; System too Lean at Idle
P2187 - 004 - - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault forPriority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 105778 km
Time Indication: 0
Date: 2000.00.00
Time: 17:46:25
Freeze Frame:
RPM: 823 /min
Load: 16.9 %
Speed: 7.0 km/h
Temperature: 74.0∞C
Temperature: 22.0∞C
Absolute Pres.: 1010.0 mbar
Voltage: 14.351 V
001287 - Idle Control System RPM
P0507 - 001 - Higher than Expected. - Intermittent
Freeze Frame:
Fault Status: 00100001
Fault Priority: 2
Fault Frequency: 3
Reset counter: 255
Mileage: 105805 km
Time Indication: 0
Date: 2000.00.00
Time: 15:23:21
Freeze Frame:
RPM: 1078 /min
Load: 13.7 %
Speed: 0.0 km/h
Temperature: 81.0∞C
Temperature: 26.0∞C
Voltage: 14.224 V
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 2
Fault Frequency: 2
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0∞C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
004243 - Bank 1; Fuel Measuring System 2
P1093 - 008 - Malfunction - Intermittent
Freeze Frame:
Fault Status: 00101000
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 107192 km
Time Indication: 0
Date: 2000.00.00
Time: 14:42:59
Freeze Frame:
RPM: 1572 /min
Load: 12.2 %
Speed: 42.0 km/h
Temperature: 59.0∞C
Temperature: 18.0∞C
Absolute Pres.: 1000.0 mbar
Voltage: 14.478 V
008825 - Leak in Air Intake System
P2279 - 002 -
Freeze Frame:
Fault Status: 01100010
Fault Priority: 2
Fault Frequency: 1
Reset counter: 255
Mileage: 107429 km
Time Indication: 0
Date: 2000.00.00
Time: 16:14:27
Freeze Frame:
RPM: 766 /min
Load: 13.7 %
Speed: 0.0 km/h
Temperature: 60.0∞C
Temperature: 27.0∞C
Absolute Pres.: 1020.0 mbar
Voltage: 14.224 V
Readiness: 0000 0001
Anyone?
Have you checked the below yet? Might get you started :happy2:
http://wiki.ross-tech.com/wiki/index.php/18619/P2187/008583 (http://wiki.ross-tech.com/wiki/index.php/18619/P2187/008583)
http://wiki.ross-tech.com/wiki/index.php/16891/P0507/001287 (http://wiki.ross-tech.com/wiki/index.php/16891/P0507/001287)
http://wiki.ross-tech.com/wiki/index.php/17501/P1093/004243 (http://wiki.ross-tech.com/wiki/index.php/17501/P1093/004243)
http://wiki.ross-tech.com/wiki/index.php/18711/P2279/008825 (http://wiki.ross-tech.com/wiki/index.php/18711/P2279/008825)
Nice one.
