All Things Mk5 => Mk5 General Area => Topic started by: michaelholt123 on February 24, 2015, 07:59:54 am
Title: golf gti cut out and wont start
Post by: michaelholt123 on February 24, 2015, 07:59:54 am
Hi guys i'm new to the mk5 gti scene. yesterday the car cut out and wouldn't start. Its like the engine is been starved of fuel maybe fuel pump etc. scanner brought up code 09529 and 12556 any ideas ? when i turn the key it fires up splutters and dies back out .......thanks guys
Title: Re: golf gti cut out and wont start
Post by: cooljimy84 on February 24, 2015, 12:27:16 pm
Welcome, and sorry for the bad start with the mk5, a quick look on google shows
http://wiki.ross-tech.com/wiki/index.php/16471/P0087/000135 (http://wiki.ross-tech.com/wiki/index.php/16471/P0087/000135)
When you open the drivers door do u heard the fuel pump prime ?
Have a check of relays (there are seated and snug) and fuses, including the ones under the bonnet next to the battery.
I take it this scan was a generic scan tool ?
Post by: michaelholt123 on February 24, 2015, 01:26:55 pm
thanks for the reply buddy yes it was just a cheap code reader i will try the following things and get back to you thanks
Post by: Teegti on November 30, 2017, 05:03:56 pm
Hi did you ever resolve this issue? currently have the same problem, my car starts and drives fine but eventually hesitates cuts out and then wont start again. both times when i go to the car the next morning it starts without an issue but eventually the same problem happens again
