All Things Mk5 => Mk5 General Area => Topic started by: K9 on March 12, 2015, 09:39:22 pm
Title: How to change steering wheel safely?
Post by: K9 on March 12, 2015, 09:39:22 pm
Hey guys and girls. Will be removing my gti steering wheel on a gti golf mk5 05. and want to hear from you who already have removed your once or twice, that how can i safely remove my wheel inc. airbag without setting it off or something like that  :ashamed: and can the indicator stalk be removed without disconnecting the steering wheel controller and install a oem cruise stalk?
Any tips how to code the new stalk via VCDS and reset the steering angle in VCDS?
Thanks you :)
Title: Re: How to change steering wheel safely?
Post by: th3_f15t on March 12, 2015, 09:42:08 pm
As for the wheel, battery disconnected is a must. Once the car is dead then there's no risk of airbag deployment, they require an electrical detonation to deploy so the age old myth that you can hit it with a hammer is rubbish.
Also, mark up the bolt you remove with a punch as you shouldn't re-use it more than 5 times.
Post by: K9 on March 12, 2015, 09:48:06 pm
What if i don't have in handy a M12 tool to get the steering wheel bolt off? Can a Torx be used to?
And when everything is back together, should the key be removed and steering wheel centered and then connect the battery and turn ignition ON? and plug-in VCDS to clear codes and steering angle? <-- how is that done? will it be easier to reset angle sensor if the computer ( controller ) is no't disconnected at-all?
Post by: doylebros on March 12, 2015, 09:56:07 pm
This is worth a watch
https://m.youtube.com/watch?v=LuZXi3VFKcg
Post by: Kam88 on March 12, 2015, 10:03:08 pm
By the looks of it you don't need coding only the tools provided
Post by: RetroRaz on March 12, 2015, 10:12:42 pm
I mentioned this in another post, you have you have to disconnect airbag, steering wheel,, steering wheel controller,  slip ring, angle sensor, and then stalk.
Post by: Rob1 on March 12, 2015, 10:14:52 pm
VW55raz has uploaded a pretty good video explaining what is needed to change the steering wheel. Unfortunately I can't locate the vid, so you may have to do a search.
Post by: RetroRaz on March 12, 2015, 10:22:36 pm
Cheers Rob.
I already linked the videos in this topic
http://www.mk5golfgti.co.uk/forum/index.php/topic,94648
Post by: savdog on March 12, 2015, 10:38:04 pm
take itto a garage .. much easier!!
Post by: K9 on March 13, 2015, 03:58:34 pm
some say that you need to code with VCDS so it knows you have cruise stalk installed?
will cost a lot to make a garage do this ( like vw ) want to save :happy2:
do i have to unplug the controller? can't it be plugged in?
Post by: savdog on March 13, 2015, 07:34:28 pm
Cost me £25 @ my local garage
Post by: K9 on March 13, 2015, 08:36:16 pm
but if i do it myself then i learn and can do friends car etc  :happy2:
Post by: K9 on March 13, 2015, 08:49:38 pm
@vw55raz (http://www.mk5golfgti.co.uk/forum/index.php?action=profile;u=6494) can i loosen the controller without needing to unplug it?
Post by: RetroRaz on March 13, 2015, 10:10:12 pm
you cant just loosen it. it has to come off. once it is off, the plugs can still stay on.
Post by: Matthewsimone on March 13, 2015, 11:03:29 pm
I wouldn't even lift the lid on my toolbox for sake of £25 mate
Post by: K9 on March 15, 2015, 06:14:07 am
Guys any how-to do do the resets via vcds?
Skickat från min SM-G900F via Tapatalk
