All Things Mk5 => Modifications & Technical Area => Technical Workshop => Topic started by: bloomus on April 02, 2015, 12:38:31 am
Hi I have a 2008 dsg GTI which I want to add the multifunction modification too I have purchased the buttons but will the module be in place then add the buttons and then get someone to code it or do I have to purchase the multifunction module aswell
Many thanks
Darren
By the way I have midline display
You'll need a new steering wheel and controller.
do you have the gear selectors on the back of the steering wheel?
Yeah it's dsg so I have the paddle shift
Then your control module will be OK and you can easily add the buttons and code it up
ill be selling a R32 flat bottom mfsw soon with DSG paddles if Interested?
As stated you just need to add the buttons. The newer type are not much use without highline display though. Can't skip tracks as far as i know
