All Things Mk5 => Mk5 General Area => Topic started by: jakex181 on April 08, 2015, 10:07:49 pm
Just wondering, my car seems to whine when im driving kinda like an electric motor sound or the sound of a straight cut gear. It's not very loud but I did notice it today with the radio off. Is this normal? Or a potential problem? Cheers.
What speed?
I changed my alternator pulley, as my clutch was slipping on it. Made a whine a bit like that while driving.
I removed my aux belt and ran the car for a seconds and the noise was not there, i checked the play on the tensinor and that was ok, so being in the middle of the range for life on the pull (60,000-80,000 miles) i had a stab and it was indeed that.
Hope that helps.
Youtube the noise, see if any match up with your noise.
it only seems to make it when im driving
What sort of speed does it make the noise as it could be a wheel bearing
it seems to stop when i get over 20mph, or i just cant hear it anymore
and it doesn't make the noise when just reving the engine at a stand still?
Does it go off when you switch off the air con?
No it only makes the sound when im driving
It'll be the gearbox whining
that doesnt sound good :/. Is this normal?
Ive just checked again and its actually making the noise when standing still so ill take the aux belt off and see if it still makes the sound. Cheers
The noise seems to have disappeared, i checked my oil level today and it was very! low, so topped it up and it seems to have stopped the noise :/. Hopefully it wasn't running that low for long
