All Things Mk5 => Mk5 General Area => Topic started by: The666 on April 09, 2015, 03:37:51 pm
So just got my wind deflectors for my 5dr gti. I have managed to install the front two with no problems, However the rear 2 deflectors just wont happen I fit it in everything seems in place but window wont close :confused: any advice did anyone come across the same prob?
bump
Can be a right PITA to get right, check that the clips are driven right in or even reposition them. Try to hold the deflector out a bit and see where it may be catching when you put up the window, kinda pull them out from the pressure point that is activating the safety system for the windows to go back down.Bit of fiddling about and you'll get there!!
