All Things Mk5 => How to Guides / Troubleshooting => Topic started by: Kam88 on June 03, 2015, 10:37:26 pm
I just fitted my valeo led rear lights and i love them but i was thinking of making them into skyline lights seen some people on forum who did this.
Now i have the lights fitted
I have ross tech vcds
But i am clueless on coding
anyone here can help me code this i can either meet up localy i live in UXBRIDGE or maybe walk me through it ?
Not as simple as that mate, a lot of modding involved.
Even thoe i already have Valeo LED lights ??? i though it was just coding required so you can se vagcom but again i am no expert
You still need to put the leds into the inner boot lights. There no wiring in the inners so nothing to code
http://www.mk5golfgti.co.uk/forum/index.php/topic,16607.0.html
You can turn off the light in the middle of the valeo outer lights, that gives it the skyline look, in vcds. To do the outer lights you need to retrofit led's.
ohh thanks guys i can't be arsed to fluff around with splitting the light and wiring leds iam happy with the result already thanks guys :happy2:
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2Fzz45%2FSI-R32%2Fdoghnut_zps9343e612.jpg&hash=0ed9fca601c4d67ce25d4bc57b7d680bb48b0ca2)
Doing the above really looks a lot better IMO, takes only 2 seconds in vcds.
i tried the coding above and every time i change it to 0 save it exit come back and its back to 20 as it was what am i doing wrong ?
any help
Did you click "do it" before closing the controller?
any before and after pics at night with this coding activated just to see what exactly it does?
yeah clicked do it then says coding accepted and nothing happened re open everything and gone back to normal :confused: driving me mad
it hast not worked for me as yet so can't show you anything :signLOL:
That's weird.....
That's weird.....
ill have to try again tomorrow see what happens
Got some valeos today and just tried this on mine and it worked a treat! Something must have gone weird on yours I'm sure it'll work when you next try
??? Any pics of what this coding does???
Don't have the before shot but it changes it from the full circles to the rings on the outer units. Looks smarter I think
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Fdaz.co%2Fmedia%2FDom_Nolan%2FMobile_Uploads%2FIMG_20150727_222537_zpsub1suneh.jpg&hash=f7c16fc9352f8bc6b4482dc689483981c7312c44)
Ill give that a bash tomorrow i think looks much smarter argh hope this works :signLOL: thanks for your reply
when changing the coding to 0 i have found if you just exit it will not save the coding
so the black box with the numbers in just to the left i click in that to highlight then simply exit and it should then save the code
hope that helps :scared:
Just did it now and accepted it did it same way as i did it few days ago i guess maybe it wasn't ready to deal with the change HAHAHAHAH cheers :signLOL: looks much better now :happy2:
Which module is the long coding located that needs changing please?
Sorted it now! Cheers
