All Things Mk5 => Mk5 General Area => Topic started by: robern2 on December 09, 2009, 01:46:16 pm
Title: Edition 30 clutch upgrade
Post by: robern2 on December 09, 2009, 01:46:16 pm
Looking for feedback from people who've upgraded their clutch on stage2+ edition30s please.
Title: Re: Edition 30 clutch upgrade
Post by: robern2 on December 10, 2009, 07:58:48 am
no one ???
Post by: bacillus on December 10, 2009, 08:33:15 am
Matt ED30 has the VWR one fitted...   :smiley:
Post by: Hurdy on December 10, 2009, 09:32:40 am
Craig at Statllers has a Sach's clutch fitted to his manual ED30. Holds the power very well, with no feel of slip. :smiley:
Post by: Tfsi_Mike on December 10, 2009, 06:04:27 pm
Maybe add Stage2+ to the tittle as there are a few S3 and Cupra drivers @ stage 2+ with new clutches....
Had VWRs upgrade recently.  Not 100% on how high the pedal is for a brand new clutch.  Its in in Jan for Diff and to add the uprated pressure plate as the wrong one turned up for my car.  Going to mention the high pedal to them then, will update.
The uprated (sintered metal) clutch disc seems up to the job and takes the abuse APR stage 2+ can throw at it.  I find it slightly juddery sometime setting off but that could be down to my driving.  Probably as I'm over cautious not to slip the clutch, having had to buy a new dual mass flywheel @ £500.....
Post by: jonnyc on December 10, 2009, 06:09:15 pm
Most of the problem with the stock 'clutch' is actually the flywheel..
Anything which uses a stock duel mass flywheel will end up having problems..
I went for a Southbend stage 5 on the S3, it was light, had incredible bite (even launch after launch after launch) and is easy to drive with..
Only downside for some would be that it makes a little noise, just chatter from the single mass flywheel.. Was £1200 I think..
Post by: Tfsi_Mike on December 10, 2009, 06:13:18 pm
Sounds perfect, only down side for me is the £1200 bit...
Post by: jonnyc on December 10, 2009, 06:13:46 pm
Hold on, it may have been $1200.. Ill just check..
Post by: jonnyc on December 10, 2009, 06:16:55 pm
Right, it was $1290 plus shipping, probably $100 as its pretty heavy, then I paid £150 to get in the UK (customs  :booty:)
So just over a grand..
Post by: robern2 on December 11, 2009, 07:53:35 am
Cheers Jonny, probably a little more than I was hoping to spend but it does sound good.
Post by: garethmk1 on December 11, 2009, 09:22:45 am
I phoned VWR day before yesterday as I'm so fed up with watching the revs fly after 2000k in 4th, 5th and 6th - gonna see if VW will fit a clutch under my maintainence package first and if not go for the VWR disc only - Matt @ VWR quoted £366.08 for the disc only but strongly advised that I buy the cover too - £420, think budget dictates it'll be the disc only - intend to purchase in January.
Post by: robern2 on December 11, 2009, 12:24:07 pm
Just booked mine in to R-tech in Hinkley, £750 all in for the sachs upgraded clutch, including a new release bearing.
Post by: gazbutS3 on December 11, 2009, 01:08:00 pm
Is that the plate and cover, no flywheel I take it?
Post by: animal on December 11, 2009, 01:54:07 pm
Are DMF issues common with the GTI?
Post by: Hurdy on December 11, 2009, 07:22:16 pm
The DMF is usually replaced alongside a new clutch, but isn't absolutely necessary. I think this is where some of the confusion/myth lies between failed DMF's and replacing healthy DMF's for the sake of it.
Post by: animal on December 11, 2009, 07:57:46 pm
I'm sure the was a LUK recall on the DMF for the Golf, but it might have been diesels. It's a common fault on diesel Focus' too, hence why I ask. Mind you, my heart is set on a DSG, so slightly different set-up on those I imagine.
Post by: gazbutS3 on December 11, 2009, 07:59:38 pm
from 08 onwards a Sachs clutch replaced the LUK item apparantly
Post by: snapey on December 11, 2009, 09:10:22 pm
Wouldn't say common issues, they only seem to fail when running mega power or being stupid as I was.... Luckily managed to get mine replaced under warranty.
Post by: garethmk1 on December 11, 2009, 09:15:18 pm
Tell me more ..... I'm on a maintainence package and still under warranty ... how fdid you wangle it ?
Post by: snapey on December 11, 2009, 09:47:22 pm
Well basically I'm still to this day convinced it was a matter of when not if it'd go. I was at the pod  :signLOL: 1st run, 3k's and just let go. No prior signs of slipping and I'm not one for sitting in car parks lighting the tyres up either so guess its just the luck of the draw.
I took it in and simply said i put my foot down from a junction and it let go. I had to wait a couple of weeks for the clutch pack, release bearing and DMF came into stock as it was a new design or something.
Post by: winrya on December 11, 2009, 09:59:34 pm
Does the clutch slip every journey, every day or just occassionally??
Post by: garethmk1 on December 11, 2009, 11:55:45 pm
DITTO !!! Exactly what happened to me !
Again ditto, driving home along the M5 I thought to myself accelerating from 2500rpm, is this clutch slipping - that was February - been getting significantly worse since then.  It's now December and 20000k later it is slipping like a slippy thing in slippyville !
I was under the impression that VW won't warranty clutches passed 6000 miles hmmmmm, I take it your clutch actually give up on you with no drive at all ? Mine has been slipping and gradually getting worse - problem is when I flash my car back to "stock" (from bluefined) it doesn't slip at all - not a bit - so obviously I take it back to the dealer and they say there is no slip quoting "our master tech has taken it out and it's not slipping at all   :sad1:"  OFCOURSE IT'S NOT WHILST THE MAP IS OFF !!!!
Anyway, just don't know what to do - hoping VW will just change it as I've been complaining of it ever since on every return to the dealers.
Do I just buy the clutch disk or do I buy the cover as well - hopefully VW will replace it under my fixed cost maintenance plan.
Post by: snapey on December 12, 2009, 12:07:52 am
Mine completely gave up the go, flywheel and clutch were pretty much friction welded together so they told me when I picked the car up from them. I had to be towed back from the pod and again to the dealer which was something I don't wish to be doing again lol  :signLOL:
It helped that the dealer I took it to was quite understanding. I'd just keep pushing it dude and get vw customer care involved.
Post by: garethmk1 on December 12, 2009, 12:20:39 am
Thought as much - they'd be pretty much duty bound to do it given the circumstances you stated, pulling out of a junction - legitimate as it gets.  I will keep pressing them - paying £80 a month in a maintenance package ! They bloody well should do it !!
Cheers,
Gareth
Post by: john_o on December 12, 2009, 12:29:27 am
kinda expected mine to go a long time ago but hasnt .....
gareth, if you can take a risk just deliberately slip it until it slips in stock mode and take it in   :surprised:
but youd have to be sure they fitted new DMF too.
just take it to VWR and have a quaife fitted too  :xmaspresent:
Post by: garethmk1 on December 12, 2009, 12:34:36 am
Been considering this - how does it continually slipping ruin the DMF ? Do you guys think I could get away with just buying the clutch disk and not bothering with the plate ?
£1800 is a big dent out of the house deposit fund - enough probably to get my strung up by my finger nails !! !!!
Post by: MAT ED30 on December 12, 2009, 01:02:44 am
The only way your going to know if anything is fooked is to get the box out and take it from
there and if vw take the box out they will see the clutch dust and the marks it will have left as it only takes Vwr under an hour to rip the box out. Just get it booked in with Mat at Vwr and get it done and then Forget about it
Post by: chungster on December 12, 2009, 08:45:04 am
This is a LUK clutch recently removed from a 2.0 TFSI Jetta  :surprised:
(https://www.mk5golfgti.co.uk/forum/proxy.php?request=http%3A%2F%2Ffarm3.static.flickr.com%2F2577%2F4138270449_6d6cd99cc5.jpg&hash=a743226475d7449375b0046a022b7c3399b2ff83)
Post by: garethmk1 on December 12, 2009, 05:20:00 pm
Somehow I can't see that turning !!!
Regards,
Gareth
Post by: winrya on December 12, 2009, 07:53:55 pm
Guys, does anyone know the part cost of an oem clutch and the labour time to replace it? Also what access would the garage have to the cambelt during this job as it could cut labour costs having it done at the same time??
Post by: danishmkvgti on December 12, 2009, 08:00:52 pm
cambelt is placed on the other side of engine  :sad1:
Post by: MAT ED30 on December 14, 2009, 12:03:38 am
look what could happen when they explode  :surprised: :scared:
Post by: garethmk1 on December 14, 2009, 02:48:00 am
lol ! :laugh:
Post by: Tfsi_Mike on December 14, 2009, 09:26:04 am
Holy sh!t  (and my first christmas tree  :tree:  :smiley:)
Post by: djhorace on December 14, 2009, 01:32:32 pm
You can get a genuine OEM stock clutch kit for less than £150 if you look hard enough. I think thats what I will go with when the diff goes in as I have had no issues with my OEM clutch.
Post by: robern2 on December 14, 2009, 05:29:41 pm
DJ Horace, what car do you have ?
I'm not going the LSD route so the upgraded clutch for my stage2+ ed30 is a must.
Post by: yin on December 14, 2009, 05:55:41 pm
DJHorace has a cupra
Post by: winrya on December 14, 2009, 10:29:43 pm
where should I be looking?
