All Things Mk5 => How to Guides / Troubleshooting => Topic started by: MrACD on June 13, 2015, 05:15:47 pm
Got hold of a friends VCDS/Vagcom and it showed the below faults.. The car has just had the chain/tensioner/adjuster replaced so battery was off and all the gubbins. I cleared them all and went out for a drive again and they still show. There are no warning lights on the dash and car seems to be driving great. Any help/suggestions welcome.
VCDS Version: Release 12.12.2 (x64)
Data version: 20140212
Saturday,13,June,2015,14:29:47:54416
Chassis Type: 1K (1K0)
Scan: 01 02 03 08 09 15 16 17 19 25 42 44 46 52 56 62 72
VIN: WVWZZZ1KZ5W247543 Mileage: 135280km/84059miles
00-Steering Angle Sensor -- Status: OK 0000
01-Engine -- Status: Malfunction 0010
02-Auto Trans -- Status: OK 0000
03-ABS Brakes -- Status: OK 0000
08-Auto HVAC -- Status: OK 0000
09-Cent. Elect. -- Status: Malfunction 0010
15-Airbags -- Status: Malfunction 0010
16-Steering wheel -- Status: OK 0000
17-Instruments -- Status: OK 0000
19-CAN Gateway -- Status: OK 0000
25-Immobilizer -- Status: OK 0000
42-Door Elect, Driver -- Status: OK 0000
44-Steering Assist -- Status: OK 0000
46-Central Conv. -- Status: Malfunction 0010
52-Door Elect, Pass. -- Status: OK 0000
56-Radio -- Status: OK 0000
62-Door, Rear Left -- Status: OK 0000
72-Door, Rear Right -- Status: OK 0000
Address 01: Engine Labels: 06F-907-115-AXX.lbl
Part No SW: 1K0 907 115 A HW: 1K0 907 115 A
Component: 2.0l R4/4V TFSI G00 0070
Revision: --H01--- Serial number: VWZ7Z0E2106207
Coding: 040300031C070160
Shop #: WSC 00000 785 00200
VCID: 2442792AE70F6F3EDFF-8071
1 Fault Found:
005634 - Power Supply Terminal 30
P1602 - 002 - Voltage too Low - Intermittent
Freeze Frame:
Fault Status: 00100010
Fault Priority: 0
Fault Frequency: 2
Reset counter: 255
Mileage: 0 km
Time Indication: 0
Freeze Frame:
RPM: 0 /min
Load: 0.0 %
Speed: 0.0 km/h
Temperature: -40.0∞C
Absolute Pres.: 0.0 mbar
Voltage: 0.000 V
Readiness: 0000 0000
Address 02: Auto Trans Labels: 02E-927-770.lbl
Part No SW: 02E 300 042 M HW: 02E 927 770 AD
Component: GSG DSG 070 0824
Revision: 04007000 Serial number: 00000504200387
Coding: 0000020
VCID: 1D344CCEC4655EF6901-8048
No fault code found.
Address 03: ABS Brakes Labels: 1K0-907-379-MK60-F.lbl
Part No: 1K0 907 379 K
Component: ESP FRONT MK60 0104
Coding: 0004738
VCID: 3A7EA752758B09CE953-806F
Address 08: Auto HVAC Labels: 1K0-907-044.lbl
Part No: 1K0 907 044 AF
Component: ClimatronicPQ35 066 0505
Shop #: WSC 00000 000 00000
VCID: 6BD052164A5160465E5-803E
Address 09: Cent. Elect. Labels: 3C0-937-049-23-H.lbl
Part No SW: 1K0 937 049 N HW: 1K0 937 049 N*
Component: Bordnetz-SG H37 0803
Revision: 00H37000 Serial number: 00000001775900
Coding: E58D0F0600041800001400001400000000087F075C
Subsystem 1 - Part No: 1K2 955 119 B Labels: 1KX-955-119.CLB
Component: Wischer VW350 012 0401
Coding: 00065493
Shop #: WSC 00000
Subsystem 2 - Part No: 1K0 955 559 R Labels: 1K0-955-559-AF.CLB
Component: RegenLichtSens 010 1010
Coding: 00207646
Shop #: WSC 00000
1 Fault Found:
01049 - Supply Voltage Term 50
006 - Short to Plus - Intermittent
Address 15: Airbags Labels: 1K0-909-605.lbl
Part No SW: 1K0 909 605 N HW: 1K0 909 605 N
Component: 08 AIRBAG VW8 015 2100
Revision: 03015000 Serial number: 0038ED0CRGNU
Coding: 0012344
Shop #: WSC 01279 785 00200
VCID: 3778BE66469914A66AD-8062
Subsystem 1 - Serial number: 6332MSME0A0A5A73G
Subsystem 2 - Serial number: 6342MSME0A0C7760E
Subsystem 3 - Serial number: 6351HSME067F5D6FY
Subsystem 4 - Serial number: 6361HSME066862523
1 Fault Found:
00532 - Supply Voltage B+
002 - Lower Limit Exceeded - Intermittent
Address 16: Steering wheel Labels: 1K0-953-549-MY8.lbl
Part No SW: 1K0 953 549 G HW: 1K0 953 549 G
Component: Lenks‰ulenmodul 521 0050
Coding: 0012142
VCID: 3666B3624193EDAE71B-8063
Subsystem 1 - Part No: XXXXXXXXXXX
Component: Lenkradmodul 007 0050
Address 17: Instruments Labels: 1K0-920-xxx-17.lbl
Part No: 1K6 920 970 E
Component: KOMBIINSTRUMENT VDD 0810
Coding: 0003403
Shop #: WSC 00015 210 70345
VCID: 326E8F72ADFBF18E5D3-8067
Address 19: CAN Gateway Labels: 1K0-907-530-V1.clb
Part No SW: 1K0 907 530 E HW: 1K0 907 951
Component: Gateway H11 0110
Revision: 11 Serial number: 29001054231257
Coding: 3F3F0340070003
VCID: 295C681E802DB256EC9-807C
Address 25: Immobilizer Labels: 1K0-920-xxx-25.clb
Component: IMMO VDD 0810
Address 42: Door Elect, Driver Labels: 1K0-959-701-MIN1.lbl
Part No: 1K0 959 701 E
Component: Tuersteuergeraet 09 0172
Coding: 0000052
VCID: 306A857AA3F7C39E2B7-8065
Address 44: Steering Assist Labels: 1Kx-909-14x-44.clb
Part No: 1K2 909 144 H
Component: EPS_ZFLS Kl.12 1502
VCID: 316C807EA8FDCA96249-8064
Address 46: Central Conv. Labels: 1K0-959-433-MAX.clb
Part No SW: 1K0 959 433 AR HW: 1K0 959 433 AR
Component: 01 KSG PQ35 G2 010 0101
Revision: 00010000 Serial number: 00000000000000
Coding: 019002085103087F2D04850560085FC690A040
VCID: 800A95BAD3D7131E1B7-80D5
Subsystem 1 - Part No: 1K0 951 605 C
Component: LIN BACKUP HORN H02 1301
Subsystem 2 - Part No: 1K0 907 719 B
Component: Neigungssensor 004 0003
Subsystem 3 - Part No: 1K0 951 177 A
Component: Innenraumueberw.005 0202
1 Fault Found:
01038 - Central Locking Thermal Protection
000 - - - Intermittent
Freeze Frame:
Fault Status: 00100000
Fault Priority: 4
Fault Frequency: 1
Reset counter: 246
Mileage: 135030 km
Time Indication: 0
Date: 2000.00.00
Time: 00:58:20
Address 52: Door Elect, Pass. Labels: 1K0-959-702-MIN1.lbl
Part No: 1K0 959 702 E
Component: Tuersteuergeraet 09 0120
Coding: 0000052
Address 56: Radio Labels: 1K0-035-1xx-56.lbl
Part No: 1K0 035 186 L
Component: Radio BVX 014 0022
Coding: 0040402
VCID: 2F688606BEC9DC6632D-807A
Address 62: Door, Rear Left Labels: 1K0-959-703-GEN1.lbl
Part No: 1K0 959 703 C
Component: Tuersteuergeraet 06 0217
Coding: 0000016
Address 72: Door, Rear Right Labels: 1K0-959-704-GEN1.lbl
Part No: 1K0 959 704 C
Coding: 0000016
End ---------------------------------------------------------------------
I also have a creaking steering rack, when manoeuvring it creaks/clicks - there is no issue with steering and road handling but it's annoying. Think it got worse after it's been raining so may need lubrication on the joints maybe?
I didn't think owning a GTi would be such a ball ache to start with!
Most of them pointing to voltage issues, start the car and leave it running for a few minutes, clear the faults and see if they come back.
