Engine/Exhaust/ECU
42 Draft Designs Shifter Bushing Set
From their site......
Eliminate sloppy shifts forever!
Our CNC machined shifter cable bushings tighten up the movement of your shifter cables, literally connecting your hand to the gears. In a performance situation, the factory rubber bushings flex causing a delay in the engagement in the gears. Our bushings eliminate this delay and provide a precision shift free of slop or hesitation.
Our shifter cable bushings are CNC machined from 6061 aluminum and fit precisely within the factory endlink. Each bushing is sleeved with an oil-impregnated bronze bearing. This bearing provides constant lubrication and a lifetime of use without wear.
Specifically machined for a variety of fitments, our shifter cable bushings provide instant results. Installation is a simple task and requires only slight modification to the side/side endlink. If you're looking to feel your shifts, these bushings are the answer!
Vehicle Specific Fitment Information
- Fits 2008-2009 VW Mk5 Jetta GLI, GTI with 6 speed transmission
- Before ordering please visually inspect the endlinks on your car to confirm fitment. Consult our tech guide for help.
- If using VW Motorsports Side to Side bracket you will need this kit.
Added by MC71, on 2014-10-29 18:32:58
Bushes
by MC71, on 2014-10-29 18:38:08
Great mod for those with stick shift. Along with a short shifter and the AKS bracket bushes this really makes all the difference to those sloppy shifts. Check on 42 Draft Designs site which one you need for your year of car then buy them from AwesomeGTI.
