Clutches and DSG
South Bend Stage 3 Endurance Clutch and Flywheel Kit
This clutch package is designed for high HP vehicles desiring a start performance similar to O.E. The pressure plate is Race Engineered (SS) and SFI (SEMA Foundation, Inc.) approved with significant load increase over stage 1,2 pressure plates (+600-800 lbs.). Expect a pedal effort increase of 20%-25%.
The disc is designed for the special needs of a vehicle with circuit racing in mind. Kevlar friction material is used for its unique static to dynamic ratios of friction coefficients at high energy levels. This translates to a perfect transition from one gear to the next. Discs are assembled with only performance components and equipped with torsion springs functioning as a damper between engine and gearbox.
Transmittable torque 480 ft/lbs.
The flywheel has a rattle sound but it's not very annoying, one can live with it .
Added by teo_parvu, on 2015-06-18 11:28:38
This mod is Wanted by the following 2 members:
