The stiff 2-piece, fully-forged calipers have designated piston sizes specific to this application and provide a firmer, more responsive brake pedal that provides better brake pedal modulation. The larger 328 x 25 mm directionally-vaned 1-piece StopTech Sport Rotors, available in slotted or drilled finishes, provide greater heat capacity and reduced brake fade. Also assisting in fade resistance and higher performance are the StopTech Street Performance Pads which have a high maximum operating temperature and high bite for responsive brakes that can be driven hard. The included StopTech braided stainless steel brake lines reduce system compliance and help provide a firmer pedal with a more immediate and better modulated response to inputs.
Added by grey golfster, on 2015-09-29 12:28:20
