Bushes
power flex anti-lift kit
This polyurethane bush fits into the rear position of the front arm and provides anti-lift properties and 1° of caster offset. It is designed to complement PFF85-501G that fits into the front position of the same arm to provide +/- 0.5° degrees of camber adjustment. This part replaces OE number: 1K0199231J, 1K0199232J & 1K0199231K,1K0199232K that includes the original bracket and rubber bush. This part replaces OE number: 1K0199231J, 1K0199232J & 1K0199231K,1K0199232K that includes the original bracket and rubber bush.
Added by Daled0111, on 2016-01-10 01:32:11
Well worth the investment
by aaronk.juju, on 2016-12-04 08:31:37
Stuck these on my Edition 30 Stage 2+ and they are great. Can be a big pain to remove old mounts as the inner stretch bolts heads can shear so be aware. Once I had the Powerflex mounts fitted and went for a test drive, I found it was well worth the money and time. Less wheel hop and less wheel spin. Traction has increase quite a lot and the car generally feels a lot more stable under acceleration and cornering. It does make the steering feel a fair bit heavier but not a problem for me. NVH is slightly increased but the benefits of the kit far outweigh this.
Powerful anti lift
by Svs, on 2017-07-16 14:57:58
Do this and the steady bar insert so much better and stable feeling with standard shocks springs watch tyre pressures steers like a mk 1 on rails and can handle speed bumps easy pleasure to drive watch out for seized bolts in rear bush bracket one into body is nearly always ok good luck
