Intakes
RAMAIR 90mm Oversize Intake
Our heat shield is far more intricate than others available and the quality of our filters are second to none. Gains on these kits are industry known to be up to 10% mapped increase with up to 25% less restriction in air flow.
Key Features:
200mm base diameter filter (competitors are only 180mm)
Airflow calculated 90mm neck filter all the way to the MAF
MAF-Safe dry foam filter with 1032cm2 Surface area.
CAD developed exhuast manifold heat sheild with unique cradle design
Added by Adam0604, on 2016-01-16 16:31:11
from 3 reviews.
Great intake
by Adam0604, on 2016-01-16 16:36:09
Great intake. Looks smart, is built well and comes with purpose built heatshields. Get many loud noises as well ! Can make it flutter nicely too. Definitely recommend.
Incredible
by GtiKris, on 2017-05-03 10:50:15
Wow... had standard air box since I had the car, moved to Ram Air Oversized and it is incredible! The sound the car makes now are superb... wooossshhhhh lol :-) It is well designed, looks like good quality product. The filter itself is huge. Feels like car lost some of the low down torque, but I don't mind as it gained in higher rev range. Above 4k feels much stronger and revs easier. Recommended!
This mod is Wanted by the following 3 members:
