ANTI-ROLL-KIT | Performance Stabilizer Bars
The suspension system anti-roll bar helps control the lateral and centrifugal forces
This reduces body roll while cornering or making fast directional changes
The system uses the outside cornering spring rate along with the rate of the anti-roll bar
During cornering and performance driving, the CoG moves back to the ideal center of the vehicle as the Anti-Roll-Bar transfer corner forces from the outer to the inner wheel
This also reduces the load difference between the outer and inner cornering wheels
The result: The ideal driving experience – „like driving on rails“
During simultaneous suspension deflection, the anti-roll bars remain neutral and the original suspension spring characteristics remain unchanged
Anti-roll bars can also influence the handling characteristics like oversteer or understeer
Added by flashp, on 2016-03-31 11:36:11
