Bushes
Vibra-Technics subframe mount (Dogbone) bush (Road use)
Direct replacement for the OE mount. This uprated mount will reduce engine movement in all directions - giving less stress on exhaust etc and giving the car a tighter feel. It also gives vastly superior comfort and isolation from engine vibration over inferior aftermarket urethane mounts.
Direct replacement for original part (can just about be done with cross member in place - but easier if removed).
The use of a natural rubber insulator gives vastly superior comfort and isolation from engine vibration over inferior aftermarket urethane mounts.
Supplied as a set it replaces OEM part numbers 1K0199868A (upper) and 1K0199867A (lower)
Part number: VAG520M
Added by Shoduchi, on 2016-12-23 12:14:46
