Roll Bars
Autotech Rear ARB 25mm
Autotech has designed these swaybars to provide increased stiffness, yet they often weigh far less than solid bars with a similar rate. For example, our 25mm lightweight front swaybar for the Golf 2 is 32% stiffer than a 22mm solid bar, yet it weighs 31% less. At the rear of the cars, where conventional swaybars get heavy, Autotech's lightweight bars can reduce swaybar weight by as much as 50%! Don't be fooled by their light weight, though! Our lightweight swaybars are every bit as strong as conventional swaybars and will probably outlast the rest of the car! Our lightweight swaybars can weigh ten or more pounds less than other bars.
Added by rich83, on 2014-10-21 11:15:19
Does the Job
by rich83, on 2014-10-21 11:16:46
This roll bar works and due to it being hollow it very very light. The only problem is it does occasionally squeak from the bushes.
