Intakes
REVO Cam Coated Cold Air Intake K03/K04
REVO Cam Coated Cold Air Intake K03/K04REVO Cam Coated Cold Air Intake K03/K04REVO Cam Coated Cold Air Intake K03/K04REVO Cam Coated Cold Air Intake K03/K04
The Revo intake features a motorsport-quality-proven, three-layer filter, with an impressive 857cm² surface area supported by galvanised, epoxy-coated mesh ensuring the filter cannot collapse. The filter has a large 180mm external diameter body and a smooth radius aluminium bell mouth specifically designed for optimum airflow from filter to pipe-work.The lightweight aluminium one piece intake has an integral MAF housing scaled to correct factory specification. To maximise airspeed the pipe diameter is kept constant through the large radius bends and smoothly tapers to the MAF housing without any stepped joins. The pipe– work features a ceramic based cam-coat technology to help reduce intake temperatures and the effect of heat-soak.The silicon inlet pipe has a relaxed radius bend and is stepped onto the turbo to ensure a smooth transition and to maintain optimum gas speeds. The K04 diverter takeoff has been carefully designed to ensure there is no disruption to airflow within the pipe.The intake features a laser-cut aluminium heat-shield that ensures the filter is well insulated from ambient under-bonnet temps, the shielding is designed to seal against the underneath of the bonnet liner and makes use of the ducting in the factory grill to maximise airflow and prevent heat-soak.The result is a system that offers over 25% less restriction than its closest competitor, allowing your car to breathe as it should do.
Added by MC71, on 2014-10-21 09:41:37
REVO CAI
by MC71, on 2014-10-21 13:27:40
On you the better Cold Air intakes there is BUT for what it is its expensive when compared to the EVOMS hence the 4 stars and not 5.
This mod is Wanted by the following 10 members:
