Springs
Eibach Pro Kit 30mm
Eibach Pro Kit
Added by Scottymon, on 2014-10-21 22:57:44
Good comfort and better body roll control
by Shoduchi, on 2014-10-23 16:21:49
Good improvement to the ride comfort adding a better dynamic behavior compared to the OEM sport suspension. Probably the best choice if you don't want to lower too much your ride height or if you have to enter more steep driveways.
Eibach Pro Kit - The OEM+ Spring
by PatchySan, on 2014-10-26 16:40:12
The 30mm Eibach Pro Kit springs are designed for those looking want to lower their car without making it too aggressive for daily driving. I noticed the progressive nature of the springs makes it relatively comfortable compared the OEM sport springs found on the GT models but is stiff enough to reduce body sway and brake squatting. Do note that the Pro Kit tend to have a "rake" appearance meaning the front end is lower than the back end, if you don't like this look you may want to consider the H&R's. Overall the Pro Kits are decent springs for daily driving, particularly when combined with the Koni FSD dampers.
Where to Buy
