OEM Parts/Service Parts
GFB DV+ Diverter Valve Kit
The solenoid coil itself from the factory-fitted valve is great (the ECU opens it faster than any pneumatic valve so why replace it?), but the weak point however is the valve mechanism itself. So GFB’s DV+ solves this problem by replacing just the valve parts with an anodised billet aluminium housing fitted with a brass piston machined to exacting tolerances.
Worth noting some people report that these still can leak boost. Click here to read the main topic about this part.
Added by Scottymon, on 2014-10-22 16:12:35
from 3 reviews.
DV+ Feels great
by Asim, on 2014-11-24 15:22:21
Fitted my DV+ plus over the weekend supplied by AMD Tuning. So far so good! You can definitely notice the difference to the stock valve. Changing in lower gears are smoother. Also as a side not the standard version i removed was not damaged.
Worth it!
by doaburnout, on 2014-12-15 00:18:16
Holds boost, throttle response is improved massively, dumps boost great between shifts, I run a standard manual GTI, don't know how it'd perform with DSG but it's great on manual!
hlcst, Monkey10, doaburnout, missymckay, ED57, MateyGuv, grey golfster, danishmkvgti, TyGTI, Asim, _Dejan_, tommy2478, mk5-beast-91, danfalcon, GAMO, ryan-g-91, Betty jnr, markos, bad devotions, RBS, Jay_87, Adrian, Paavo, Sammasson, Shoduchi, Neil 54, AndrewWillis, leebes, aaron92, aaronk.juju, chrism3, Octoparrot, P3T3R, JamieKirk95, warpigroadkill, Timmsy21, absolute, nikolov92, finna00, grizzlydean, Clarky, declan.obyrne,
Related Topics
