Author Topic: omg what a difference.  (Read 6048 times)
Offline ReflexRob
Re: omg what a difference.
« Reply #15 on: August 13, 2015, 12:39:57 pm »
I'm actually getting pretty fed up of this car I have to say.
Sold my 145k 325Ci running as sweet as a nut to get a newer lower mileage car for work commuting. I fancied a change and was chasing a few rust spots around on the edges here and there.
So far with this 50k GTI I have learnt in 3 months of ownership that I have needed or will need to:
1/ Check & change cam follower that could damage the engine Thankfully this was fine but I changed it anyway - Potential £800+ damage avoided only because of this club.
2/ I need to replace the cam chain and tensioner (hopefully not adjuster) due to diesel sound when fully warm that didn't manifest itself on my 20 minute test drive at purchase - £500 parts and labour
3/ Clean up coking on valves - £500
4/ Hope my wings don't rust.
5/ Change split DV - £40 every few years possibly
The car has been well maintained and has only done 50k! My last VW, a 1986 Jetta TX was designed so much better in comparison.
I also have a 1993 MR2 Turbo putting out 245bhp as standard on 115k that just needs servicing once a year.
Joke!
Offline flashp
  • -Receive: 65
« Reply #16 on: August 13, 2015, 01:47:40 pm »
Joke!
I had item 3 on your list carried for significantly less that £500 by JKM. 3 hours labour and some materials put the job at about £250 iirc.
Gone but not forgotten :-)
Offline Black66
« Reply #17 on: August 13, 2015, 03:35:28 pm »
How easy is inlet manifold off?
Offline guyrocks
  • -Given: 17
« Reply #18 on: August 13, 2015, 04:35:07 pm »
Sent from my SM-G900F using Tapatalk
Offline guyrocks
  • -Given: 17
« Reply #19 on: August 13, 2015, 04:36:01 pm »
This is what you need my m8 does it at sea view performance Horden co durham
« Last Edit: August 13, 2015, 04:45:38 pm by guyrocks »
Offline david25
  • -Given: 19
« Reply #20 on: August 13, 2015, 06:59:10 pm »
Read here, there is another indy using FORTE stuff
http://www.pistonheads.com/gassing/topic.asp?h=0&f=86&t=1522030&mid=173159&nmt=AUDI+S6+V10+-+Carbon+Clean
If it works for a V10 then it must be good?
