Author Topic: Stutter when blipping throttle  (Read 2718 times)
Offline GTIEagles
« on: August 12, 2015, 09:21:08 pm »
My car has always done this but today I thought I would investigate a bit further. Basically when I blip the throttle hard from idle the engine briefly stutters. I hooked VCDS up and viewed the measuring blocks groups 015 & 016 Misfire Detection, everytime I blipped throttle hard the count went up on all 4 cylinders.
The car never misfires whilst driving normally and hard.
The coils have been changed under recall from VW a couple of years ago and the spark plugs were changed about 14K ago.
No fault codes.
Any ideas?
Offline GTIEagles
Re: Stutter when blipping throttle
« Reply #1 on: August 14, 2015, 12:50:15 pm »
Clogged inlet valves  :happy2:
You sound pretty certain, have you had the same symptons?
Offline GTIEagles
« Reply #2 on: August 14, 2015, 06:28:47 pm »
No, it idles really steady. Even using the throttle normally it doesn't misfire just when you snap the throttle open it does it.
Offline GTIEagles
« Reply #3 on: August 14, 2015, 08:52:47 pm »
I could try a new set but they were only changed 14k from VW so I'm doubtful.
Any proper way to test the MAF or is it the case of just unplugging it?
I have done the throttle reset a couple of times and it instantly feels better but it reverts back to how it was before after a while.
Offline john87
  • -Receive: 53
« Reply #4 on: August 17, 2015, 12:28:45 pm »
Is the car remapped?
My R32 did this after a remap, and stopped doing it once the map was taken off...
Offline GTIEagles
« Reply #5 on: August 17, 2015, 01:14:36 pm »
No, it's completely standard. I will try to get a video of it tonight.
Offline GTIEagles
« Reply #6 on: August 17, 2015, 01:15:43 pm »
You might of just answered your own question ??
When I say better I mean that the throttle response seems softer and more easy to drive but it still misfires.
Offline GTIEagles
« Reply #7 on: August 19, 2015, 09:15:15 am »
You need to turn your sound up, prefably on headphones. You can hear the slight hesitation.
