Author Topic: Engine Misfiring & Engine Mangement Light On  (Read 919 times)
busboygeo
« on: August 14, 2015, 02:08:49 am »
Hi Wonder If Anyone can Help
My engine management light came on the other day & it started to idle erratically, also when I accelerate it judders & it takes its time to pick up some speed. I changed the plugs & it didn't fix the problem, also checked coils I then put it into a garage & they said they cleared the faults that were showing but said the camshaft sensor code kept coming up, so they changed the sensor & it didn't solve the problem, took it to an Audi VW Repair Centre & they had a quick look & said that the same code keeps coming up on the Vag Com relating to the camshaft sensor, but he did say it isn't a misfire & he can't check it out properly for another wk Anyone got any idea what it might be  CHEERS
